Ford 1710 3 point hitch piston seal
   / Ford 1710 3 point hitch piston seal #1
ericoberg1
Member
Simi Valley, CA
Ford 1710
Getting read for fire abatement here in Southern California. Finally getting around to putting a new seal on the 3 point piston. If I dropped the throttle to idle or shut the engine off, the attachment would drop.
3 point hitch piston pulled out.
The seal on the piston was just crumbs. After 35 years, the two o-rings were still pliable, but since I had new ones, in they went.
All cleaned up and installed.
Now, the 3 point stays up, AND the front loader is a bit more perky. I probably spent more time cleaning off dirt and grime, then cracking loose the bolts than putting new the new seal and o-rings.
   / Ford 1710 3 point hitch piston seal #2
Maybe get an inexpensive pressure washer?
I have big ones, but have heard that Sun Joe electric is quite good, and cheap.
No electricity where I have the tractor. Spray cleaners, jug of water, rags, scrub brushes...
   / Ford 1710 3 point hitch piston seal #4
Very un-handy!
Maybe...... move the tractor for repairs.
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
VENTRAC 4500Z ARTICULATING TRACTOR (A51242)
VENTRAC 4500Z...
2018 FREIGHTLINER CASCADIA (A50854)
2018 FREIGHTLINER...
Bus (A50323)
Bus (A50323)
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
