Watch "#386 DON'T let this happen to YOU!" on YouTube
   / Watch "#386 DON'T let this happen to YOU!" on YouTube #11
Yeah. That is the last thing a FEL was designed for.
I have seen trees fall on the engine house of a large excavator. The owner was not impressed with his operator. If done at all, most good operators will have the hoe stretched out far, to avoid danger as much as possible. You don't have that reach with a FEL.
I think, if you make a habit of pushing over trees, you WILL eventually have an acident.
   / Watch "#386 DON'T let this happen to YOU!" on YouTube #12
I’ve heard you should never push trees with an excavator with the machine turned 180 degrease on the tracks because of the trees branches fall into the cab it’ll push the drive levers backwards with will drive the machine farther into the tree.
   / Watch "#386 DON'T let this happen to YOU!" on YouTube #13
What's really funny is when YT stops the RK commercial for another commercial. :D
I have a short attention span, so was already bored before she came out to pat the chicken.; that's as far as I watched.
I tried unsuccessfully to find out more about the Ford in the tree; maybe I'm wrong but that just doesn't look real.
   / Watch "#386 DON'T let this happen to YOU!" on YouTube #14
Yeah... I just lost 15 minutes waiting for "Don't let this happen" and it never came. This dude used to have a Kubota and somewhat cool video's, now it's just a Rural King channel....
Still has his kubota .He is just using better tractors now .
   / Watch "#386 DON'T let this happen to YOU!" on YouTube #15
"He is just using better tractors now"
Of course he is!
   / Watch "#386 DON'T let this happen to YOU!" on YouTube #16
I have taken down several acres of trees with an excavator and not once have I had one fall on me or a branch fall on the cab. There is a certain way to do it and typically a guy doesn't just push it over. You dig the roots around the tree except the ones opposite of the machine (so roots keep tree from falling on you) and then push it over. I have had trees where i couldn't push them over and had to pull them to me but away from me. As I said there is a way to do it especially if you are a seasoned excavator operator. If not then don't try it
   / Watch "#386 DON'T let this happen to YOU!" on YouTube #17
   / Watch "#386 DON'T let this happen to YOU!" on YouTube #18
Ok, I'll just stick to pushing over or pulling over trees, which ever the case requires, with my tractor.
But sometimes even seasoned operators of all types of equipment have accidents. Do something long enough and often enough, the unexpected can happen to anyone of us.
   / Watch "#386 DON'T let this happen to YOU!" on YouTube #19
I think some folks are being a little hard on the YouTube presenter. Yes, it's an RK sponsored channel... But he's basically discussing a viral tractor photo and pointing out potential dangers. If just one operator thinks twice as a result of watching this video I would call it worthwhile.
   / Watch "#386 DON'T let this happen to YOU!" on YouTube #20
It would be a lot easier if he hadn't spent 16 minutes to do a 2 minute presentation. I have to sit through that type of drawn out presentation occasionally at work; but not on my own time.
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2018 Ford F-350 4x4 Ext. Cab Stellar FC3200 3,200lb 1.5 Ton Service Crane Truck (A55973)
2018 Ford F-350...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
2017 Ford F-250 Service Truck (A56858)
2017 Ford F-250...
SOFTBALL & BASEBALL HITTING & CATCHING GEAR (A58374)
SOFTBALL &...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
