When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need?
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #1
MA1920
Central MA
Ford 1920
Just wondering what the potential repairs will be on a hydro tractor as it ages?
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #2
Basically the wear issues one would associate with hydraulic pumps and motors.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #3
An oil change.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #4
If you meant 1000 hours, it probably needs an oil and filter change as Eric said.
If you meant thousands of hours, it will probably need a rebuilt kit for the pump and motor, which includes all the wear parts (piston, swash plates, thrust washers, etc) and seals. This may or may not be hard to find if not impossible but will definitely get expensive.
HST transmissions are usually made by big hydraulic/transmission manufacturers, so, who knows if they will keep making repair kits for older transmissions? And when the transmission gets to the point of needing a rebuild, does it worth repair for more than the tractor worth or just trade the tractor?
But if proper maintained, it should last for a long time. Pretty much as a clutch, if the operator knows how to use it, you can get over 5000 hours of it.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #5
I was thinking if you put 1000 hrs on it WITHOUT changing the fluid and filter, it may already be too late!
My JD Power Reverser trans needs fluid and filter every 400-500 hrs. If you let it go very far past that, it'll let you know. Trans light will start to blink sometimes when you do a forward to reverse. And the hydraulics will slow down a bit. Fresh oil and filter, and it's good to go again.
My 32 year old Ford is a basic geared transmission. IF I ever get a new tractor (highly unlikely), I was curious as to the possible repair bills with a HST.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #7
It will be very interesting to see whether all the various hyrostats out there are created somewhat equally, given some time and hours. Or whether some turn out to be clearly superior or inferior.
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #8
My 1920 is only two years newer than yours.
Great machine....I will NEVER sell it!
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #9
IF kept up properly with oils and filters changed probably go forever and when it fails it fails, hours may mean very little... On my tractor, it says oils and filters at 50 hours (first time) and ever 250 hour after..... Only time (hours) will tell.....
Dale
/ When a gear tractor reaches 1000's of hours it needs a clutch; what does a HST need? #10
I keep up on maintenance.. my tractor has 980 hours on it...going strong
2025 AGT Industrial MX-MRW14 (A60463)
2025 AGT...
LOAD OUT AND SHIPPING (A61165)
LOAD OUT AND...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
SANY SY35U EXCAVATOR (A59823)
SANY SY35U...
2006 CATERPILLAR 420E BACKHOE (A59823)
2006 CATERPILLAR...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A59908)
2016 INTERNATIONAL...
