Jd 4310 mfwd selenoid wires
   / Jd 4310 mfwd selenoid wires #1
disco
Minnesota, Goodhue County
JD 4310 & JD 4020
Wires got pulled out of weather pack connector. Found new female pins at case dealer. Blue bobcat wires worked. Got pto hooked back up. Working good. Anybody know what wire coming out of mfwd selenoid is the hot wire?
Thanks
   / Jd 4310 mfwd selenoid wires #2
Post a pic or two of the problem and the solenoid and I'll see what the service tech manual shows for the hot wire..
You say "working good".. is there something not working?
Pto wires are in same connector as mfwd wires. Pto works as should after reattaching wires. My question is I know on the male side coming from switch. White is hot and black is ground. 2 wires coming from mfwd selenoid are black. Does it matter? I would think so. Which one is the hot wire.
Thanks
Went with the one on the left. It was the hot wire on the pto side.
   / Jd 4310 mfwd selenoid wires #5
Thanks
A solenoid is just a coil. I ASSUME hook up either way will work.
UNUSED FUTURE FT36C STAND ON SKID STEER (A57192)
UNUSED FUTURE...
Golf Cart (A55787)
Golf Cart (A55787)
Cattle Feeder (A56469)
UNUSED FUTURE 44" EXCAVATOR RAKE (A57193)
UNUSED FUTURE 44"...
1990 Ford F-450 Heil 10FT S/A Dump Truck (A55852)
1990 Ford F-450...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
