Backhoe Thumb
/ Backhoe Thumb #1
downsizingnow48
Elite Member
Sacramento, California
Kubota B21
When I first built my hydraulic thumb, I bought a Kubota thumb to save time. The B21 never had a thumb. The one I got is made for a B76, but by comparing bucket pin part numbers I figured out it would also fit a B21 hoe. It fit perfectly.
After a while I added a quick coupler to the backhoe so I could change easily between digging bucket, landscape bucket, ditching bucket, and root ripper. That changed the relative positions of bucket and thumb and messed up the thumb closure.
I tried to live with it but too much functionality lost. This winter I decided to make a new thumb. Photos show the wood template, cleaning up the main rails, tacking everything together, test fit, and final installation. Fit is again perfect. I added a bit of extra curvature because the factory thumb was too flat, had a tendency to squeeze stuff out.
The main rails are 1/2" steel, all the gussets are 3/8". I followed the design of the factory thumb on bracing.
Photo 1 - perfect fit.
Photo 2 - not a perfect fit.
Photo 3 - template.
Photo 4 - cleaning up the main rails after plasma cut.
Photo 5 - tacked up.
Photo 6 - test fit.
Photo 7,8 - installed.
/ Backhoe Thumb #3
Did you build your sander? That thing looks sweet. Does it go adjust vertical?
I have been thinking about building one and looking at different designs. It looks like this one was very well thought out.
/ Backhoe Thumb
I studied them for a couple months. Finally bought the grinder from a place called The Belt Grinder in Minnesota. I got the motor and controller separately.
I started out wanting to make one from scratch but I have too many projects lined up.
I added a hinge so can be used either vertical or horizontal. Both positions are needed at least for what I do.
For years now I have been using an upside down belt sander as a grinder, it has worked well. Based on that I decided to get a real belt grinder. It is much more powerful and versatile.
/ Backhoe Thumb #5
I tried to live with it but too much functionality lost. This winter I decided to make a new thumb. Photos show the wood template, cleaning up the main rails, tacking everything together, test fit, and final installation. Fit is again perfect. I added a bit of extra curvature because the factory thumb was too flat, had a tendency to squeeze stuff out...
Well done! I just recently bought the BXpanded Barracuda Factory Fit Thumb for my BH77 backhoe. I chose it over a Kubota OEM thumb for three reasons: First was the BXpanded thumb costs less. Second, I felt the BXpanded design with the curved jaw was better. Finally, this one is the long jaw version which was specifically designed to work properly with my BXpanded quick-on bucket connect so that the thumb meshes properly with the bucket edge and teeth. There is a shorter version for folks without the quick-on bucket connect. Attached is a picture of the thumb and how it meshes with my 16" bucket and BXpanded Quick-on Bucket Connect, which makes switching to my trencher bucket or ripper tooth really quick and easy.
Here is a video of me installing, and testing the thumb for anyone interested:
BXpanded Backhoe Thumb for My Kubota - YouTube
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A59823)
2017 KALMAR OTTAWA...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
CAT B30 HYDRAULIC HAMMER (A60736)
CAT B30 HYDRAULIC...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
