2555 HST run away
/ 2555 HST run away #1
skullmount
mahindra kubota ford
Newbe here, but have lurked for a while off and on.
I have a 2555 HST with cab that I purchased used late last winter, at 545 hours. I do snow removal at a retirement community. This is a "back up" machine that saw only 20 or so hours during the spring and summer at my place and a friends. Last fall I moved it from my place to the site and it saw limited use, 15 to 20 hours or so, as my Kubota was not on site early in November. In late January we had an issue with the Kubota, so the 2555 was used. Temps were in the teens and it ran a bit rough, with a bit of run on.................parked it . Talked to a couple dealers and also spent quite a bit of time on this site. (EGR system issues )Thinking that the temps had something to do with the rough running etc, I left it parked till the temps got near 35 or 40. Went over to the lot where it was parked and it started right up and ran fine. Talked to the dealers again and both urged me to get it in to be "flashed" for the cold temps here in Michigan, (between Jackson and Ann Arbor) did get to 18 below one morning on site.
Waiting on parts for the Kubota, we had to use the 2555 for snow again. I used the machine overnight and it started running rough again, temps were in the mid to high 20's, I took the machine back to the polebarn and parked it, running, and was looking it over and it "ran away"..............I reached in and turned the key off which did nothing to stop the engine as it had started to suck oil thru the turbo, air to air cooler etc.
Lots of smoke and oil blowing out of the exhaust, finally quit after 12 to 15 seconds. So I am thinking that it sucked the oil out of the pan and how low is the oil now ???:confused2:
Was way up the stick:confused:
Drained the oil, measured what came out and what it took to re-fill, it was a gallon overfull. After lots of phone calls and talking to a couple diesel buddies my one mechanic friend talked to a Mahindra dealer in mid-Michigan, that said they have seen it twice in the past and that there is a seal in the hydraulic pump that dries out and feeds oil right into the motor.
Lots of hunting and pecking to get to this...............dealer told my friend that after draining the oil and getting the right amount in there, the 2 they have seen do this started fine, ours did not. With these guys help everything checks out to the injectors. Pushed it inside today and will hopefully get an injector or 2 out to look at and get tested. Have any of you guys here seen this?
Looking down the road..............How does one go about cleaning the catalyst chamber and the air to air cooler on the inside ??
carl
/ 2555 HST run away #3
I’m having a hard time believing the EGR is the issue. I’m also having a hard time believing the injectors only leak when very cold- that should be the opposite!
My hunch is the fuel is gelling just enough to cause these issues- rough running since it’s gummy and just gummy enough that the fuel shut off isn’t happening when you turn the key off.
I’d unplug the EGR when it’s cold and rough running to see if it smooths out- unplugged should shut the EGR.
I’d also pull some fuel and put it in a mason jar or similar and see what it looks like at the low temps.
As for the hydraulic leak into the bottom end....could be related or totally unrelated- I’ll SWAG for the latter.
I do know that flashing the computer has helped folks but I’ve never seen this happen.
/ 2555 HST run away
What’s the factory warranty status of the tractor? It has a fair bit of time on the emissions warranty.
Not sure, as I am the second owner...............will look into that one.
/ 2555 HST run away
..............As for the hydraulic leak into the bottom end....could be related or totally unrelated- I’ll SWAG for the latter.
our theory .......................oil was sucked into air to air cooler/ turbo and it ran on that hot oil (run away)
There is slight oil residue in emissions pipes and tubes and a very small amount in the bottom of the air to air cooler.
Could the injectors be plugged up from running on the oil, in reality the fuel also cools the injectors as fuel is sprayed into cylinder, maybe they are "cooked" shut ???
/ 2555 HST run away
What we found today............. catalyst plugged with partially burned oil, injector tips burned off to various degrees.
So does anyone have a clue as to how the catalyst gets cleaned up again ??? High temp industrial oven maybe ??
/ 2555 HST run away #7
Again I will suggest you pursue your warranty, let Mahindra clean this mess up. You also need to investigate the turbocharger as the probable cause of the engine oil that the tractor was running away on. Do not be concerned with cleaning things up, let the manufacturer supply new parts.
/ 2555 HST run away #8
Being overfull in the engine oil reservoir is definitely a problem but can't say for certain if it's your only problem. Just like in other diesels the oil level can rise from excess idling since the fuel may not be fully burning and it can end up below the piston rings where it drains back into the oil.
A few questions:
1. Do you know when it was originally sold? The warranty starts on the date of first sale, not necessarily on the date it was built or shipped to the original selling dealer. Was it a 5 year warranty machine?
2. Do you know for certain when the last engine oil change was done, at what hours?
3. Does the oil seem excessively runny like it has been diluted with fuel?
As others have stated, first step is figuring out number 1 because if it is within warranty Mahindra is pretty good about taking care of warranty claims and fixing things. If they can't figure out why it did it and if there's damage to the engine they may replace the whole engine. It is well worth your time to check into it.
/ 2555 HST run away #9
There is no question that the tractor is within the EPA emissions warranty period. This covers a surprising amount of engine components and parts. Basic warranty can be determined by providing any competent Mahindra dealer with your serial number.
/ 2555 HST run away #10
Did you buy your tractor from a Mahindra dealer? you should be covered for emission system warranty. there is a field mod for a ECU reflash that may have prevented your problem.:shocked:
/ 2555 HST run away
A few questions:
Sorry about my absence.......been crazy busy.
answers..........
That purchase info was sent to warranty person in texas. we found out I was not listed as the owner yet in their warranty system
According to the dealer who maintained the machine all new oil filters, when I bought it
Nope just oil, no fuel is present
A retired friend has contacted mahindra for me and is provided all the info to them and we are waiting on a reply. will update as I can.
/ 2555 HST run away
I believed two dealers when they told me that it was running rough in the cold temps...................... still needs to be done. Not sure how a computer flash would prevent a seal from leaking hyd oil into the motor ???
/ 2555 HST run away #13
I meant the reflash may have prevented the fuel system issues. I have seen the work pump seal fail but it usually empties the hyd fluid pretty quickly.A you sure that's not fuel in the crank case?
/ 2555 HST run away
OK, got your idea on the flash.
definitely not fuel, just oil came out
/ 2555 HST run away #15
Mahindra or a Mahindra dealer simply has to determine the warranty status of your tractor. A competent dealer can do it on the computer by visiting the warranty section of the dealer access Mahindra website. I used to do it all the time when my boss sold them and the shop I supervise repaired them. No calls or contact with Mahindra personnel nor does the tractor have to be registered to you in their data base. It is either in warranty or it is not. If it is in warranty an authorized Mahindra dealer is obligated to make covered repairs.
/ 2555 HST run away
RickB,
IMHO, of the 4 dealers we have talked to, only one made the right connection as far as to what really happened here. I provided the serial number etc to one of the dealers, who also pestered me a few times about getting the machine to their shop............if i was unable to get it there, they would pick it up. I was led to believe that I had no warranty by 2 of the dealers I talked to, because I purchased the machine used.
your word choice here is key "competent"
/ 2555 HST run away #18
RickB,
The warranty follows the machine, not the owner. If it is within the time frame then it is most likely covered.
/ 2555 HST run away #19
That is incorrect :eek: unit must be transferred to new owner for warranty to be valid.:shocked: I get Mihindra customers in all the time thinking there used tractor is still under warranty. Its a real shame because its an easy process to transfer. a simple phone call to the dealer from the owner with the buyers info.
/ 2555 HST run away #20
That is inconsistent with my experience as the service coordinator at an authorized Mahindra dealership. If a Mahindra owner has a tractor with a warrantable problem within the appropriate warranty period that’s all I needed to know. Make the repair, file the warranty claim, get the warranty credit.
2023 John Deere Z930M Zero Turn (A63116)
2023 John Deere...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
