Simple hold-open for hydraulic valve
/ Simple hold-open for hydraulic valve #1
pmbutter
Ontario, NY
LS R4047
I run a backhoe on my LS R4047, but didn't invest in a valve with detent. Instead, I build this little sliding hook, with a bolt, nut, washer and spring. Pretty simple. Does the job. Offered here for your amusement. 20190312_115154.jpg20190312_115216.jpg20190312_115307.jpg
/ Simple hold-open for hydraulic valve #3
/ Simple hold-open for hydraulic valve #4
Just wondering if running through the control valve instead a PB is doing and damage like to spool valve or bypass. Don't know but I'd think the valve isn't designed for constant use. If not damaging anything real easy way to plumb a BH.
/ Simple hold-open for hydraulic valve #6
It wont hurt anything as long as it doesn't get latched on with a hydraulic cylinder on there (or with nothing connected) so that the fluid doesn't have anywhere to go and the pump is sending all of the flow over the pressure relief for more than a little bit.
Aaron Z
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2017 International HX620 Quint Dump (A62613)
2017 International...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2022 EZ-GO ELITE...
