Now you are getting older - what don't you do?
   / Now you are getting older - what don't you do? #241
In a nutshell.... I consider life is a lottery and doing stupid stuff will get you killed. The last 30 years in a patrol car have given me hundreds of examples.
   / Now you are getting older - what don't you do? #242
I reach 75 in a few weeks and old injuries from rugby and horses falling down are felt more than they used to be. I have always (I hope) thought about safety issues when doing anything. My knees can give way from time to time and so a couple of years ago I stopped using chainsaws - a face full of moving chain is probably not good for the complexion. I no longer climb ladders either. I made a "cherry picker" for the tractor link box and use that for picking the higher branches of olive trees.
A bad fall when visiting England a year ago means my right shoulder is not so good anymore and I cannot lift heavy weights so do not attempt to do so. I try to plan things so that I do not have to mount and dismount the tractor too often in a day. Just commonsense things really.
I have also decided I want to retire and spend a few years fishing in the Azores.
   / Now you are getting older - what don't you do? #243
Years ago I liked the TV show "The Real McCoys", grandpa (Walter Brennan) was so funny the way he walked. Now I have grandpa's walk...especially when getting out of my recliner!
What causes that?!?
   / Now you are getting older - what don't you do? #244
I discovered Sunday that I do not function well for the day when I get up before the sun does.
   / Now you are getting older - what don't you do? #245
I try not to drive after dark. To many light halos and no peripheral vision makes it difficult.
   / Now you are getting older - what don't you do? #246
The halos may be indicative of cataracts forming.
   / Now you are getting older - what don't you do? #247
   / Now you are getting older - what don't you do? #248
   / Now you are getting older - what don't you do? #249
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
TAKEUCHI TB210R EXCAVATOR (A51242)
TAKEUCHI TB210R...
