What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #423
You'll be very pleased with your grader. When I got my 84", I had an XR4046HC (in picture below) and it pulled it fine.
Now I've got an XR4155HC ...... even better!
Pictures when you put yours to work ..... it's the law.
I contemplated getting the 84, but wasn't sure if i壇 like the extra over hang on the sides when I tilt the angle. Figured it may be too much if I知 running my tractor at a side angle since my driveway is raised up.
   / What did you do on or to your LS Tractor today? #424
I have hydraulic top and side links plus moved the adjustable manual side link on left side. I’ve got lots of tilt capabilities but rarely use much tilt on the grader plane.
My 96” Land Pride rear blade is different. I tilt it a lot.
I've been trailblazing. Cutting a rough walk path/trail by hand through a wooded area. Using the FEL bucket as a tool carrier for saws, gas/oil, two stroke stuff, etc. Once I get the tougher stuff cut out, I hope to be able to trim it all with the MMM. Not sure if that'll work yet or not.
   / What did you do on or to your LS Tractor today? #426
Yeah you致e got a nice setup. I致e thought about getting a hydraulic top link, but haven稚 decided if I壇 actually use it much.
   / What did you do on or to your LS Tractor today? #427
Built a pad and moved an RV carport onto it.
Used the LS and power rake to do the final leveling on the dirt and crusher run. Then used the LS to haul the generator, scaffolding, ect. around the job site.
   / What did you do on or to your LS Tractor today? #428
Took down one of several widow makers today. Hard to tell in the picture but it's the tree above the right side of the grapple. The LS and grapple safely removed it and all the debris. Wahoo!
Ran the Torque App while putting some hay out for the cows just to see what it would do. The data here is cruising with a round bale on front.
Yep, using Ford and generic pids and a OBDLinkMX.
Is there a list of what models that works with? I don't even know if I have an OBD port.
   / What did you do on or to your LS Tractor today? #430
Put on my new ratchet rake! I caught a break in the rain, but it's been pouring since and I haven't been able to play with it. IMG_20190313_170103508.jpgIMG_20190313_170105894.jpgIMG_20190313_170110941.jpg
2013 Ford F-250 (A56858)
2013 Ford F-250...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
Toro Dingo Mini Skid-Steer Mounting Plate (New/Unused) (A59225)
Toro Dingo Mini...
POLY TOTE W/ WIRE CAGE & PALLET (A52708)
POLY TOTE W/ WIRE...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
