flingwing1969
- Joined
- Jun 2, 2008
- Messages
- 688
- Tractor
- LS G3038, JD GT275, and Bolins H16
Yes, usually a residential fire sprinkler system can be supplied by a well - some jurisdictions have codes on how much water for how long must be supplied and power failure provisions might be required.
b. Check your policy - I usually add replacement value (RV) to my policies (if available) since you will otherwise only get actual cash (ACV) value of a lost item at the time of the loss. With ACV a ten year old couch will be valued at what a ten year old couch is worth if you sold it whereas with RV, you get a new couch of similar quality. Check with your agent and also check with other companies.
A normal homeowners policy contains comprehensive fire coverage. You can sometimes obtain similar coverage without the other provisions of a HO policy (liability/theft/other damage/etc) but, if you can get a full coverage HO policy, why would you not get it since the cost of the fire only coverage is often as high or higher in some high-fire-danger areas.
