Semi rural living - Fire safety & water provision best practices
/ Semi rural living - Fire safety & water provision best practices #21
Yes, usually a residential fire sprinkler system can be supplied by a well - some jurisdictions have codes on how much water for how long must be supplied and power failure provisions might be required.
b. Check your policy - I usually add replacement value (RV) to my policies (if available) since you will otherwise only get actual cash (ACV) value of a lost item at the time of the loss. With ACV a ten year old couch will be valued at what a ten year old couch is worth if you sold it whereas with RV, you get a new couch of similar quality. Check with your agent and also check with other companies.
A normal homeowners policy contains comprehensive fire coverage. You can sometimes obtain similar coverage without the other provisions of a HO policy (liability/theft/other damage/etc) but, if you can get a full coverage HO policy, why would you not get it since the cost of the fire only coverage is often as high or higher in some high-fire-danger areas.
/ Semi rural living - Fire safety & water provision best practices #22
Depending on your budget I壇 suggest having a residential sprinkler system installed. Oasis fire protection is a company for example. As for the Knox box, get with the county fire Marshall so you can get it keyed correctly. Hopefully it値l never be used but they are very useful and would be nice if they were mandatory.
If you have a pond a dry hydrant would be useful for drafting but a turbo draft site would also be handy
Brett
^^^ This ^^^
If you have a fire, the house will be fully involved before the fire department can get there. A residential sprinkler system is the only way to save the structure. I have a similar situation and a buddy who is a fire marshal. This advice comes directly from him.
As long as the gate is light enough to not damage the engines, they will drive right through it, or alternatively through fences. A cattle guard is a better idea. Their priority will be preventing a range fire, because they know the house is already a total loss.
/ Semi rural living - Fire safety & water provision best practices #23
Speaking of wildfires, clean your gutters. In dry weather, the duff in the bottom of the gutters turns into tinder. A single ember will set it on fire, where it will set the eave of the house on fire. Standard 3-tab shingles are Class A fire resistant, so an ember landing on the roof will just go out. If it lands on tinder in the gutter, all bets are off.
/ Semi rural living - Fire safety & water provision best practices #24
If a wildfire ever does reach my house and outbuildings - I do not expect that anything would be saved. I have a five acre lake, 80 feet deep, just 100 feet from my front porch. Based upon my experience with the wildfire, five years ago - Watermelon Hill wildfire - any type of sprinkler system that could even stand a ghost of a chance to save the house and outbuildings would be totally cost prohibitive. It would not only require a large system to pump out of the lake but also a large standby power supply - we lost power during the wildfire five years ago.
/ Semi rural living - Fire safety & water provision best practices #25
Basically the residential sprinkler system is designed to try and keep the fire in check so the occupants can escape. Or buys time. That being said, they can extinguish the fire too but with the constraints of pipe size and incoming water I don’t want to oversell. I ran the numbers when we built and it would take 40 years to recoup the money, I had my head up my rear and kick myself. The cost was mearly a drop in the bucket at the time and I have no good reason for not doing it. There are companies that will install them for free, just have to buy the material for career fireman. Can’t beat that deal
Brett
/ Semi rural living - Fire safety & water provision best practices #26
He's talking about external sprinklers, like what we have on our house. Ours were added by the builder/previous owner during construction when it was really cheap to do so. Since we have a gravity powered water system and a 10,000 gallon tank, there'll still be water pressure when the power goes out. We get a discount on the house insurance because of the sprinklers.
Most of what helps save rural homes from wildfire is vegetation management around the house and keeping flamables away from the home. (for example, that stack of fire wood next to the garage). Fixing those are things that anyone can do. The guidelines in the link I posted earlier are useful.
/ Semi rural living - Fire safety & water provision best practices #27
OPs location isn’t at much threat for wildfire. They are surrounded by pine plantations but if it was to burn like it did to the West 60 miles in 2011 there isn’t much that can be done unless you have a huge multi acre buffer. Typically most just clear an acre or two around the house for privacy and only clear more if they want pasture. I hate pine so we cleared everything except the hardwoods
Brett
How have you been @rustyshakelford? It looks like sprinklers are something to consider. I presume the sprinklers are the indoor sprinklers like one often sees in hotel rooms?
Or are these sprinklers outside the home that spray on the home? Or both?
I presume if they are indoor sprinklers they will require a lot of breaking walls, ceiling etc?
You all have been so helpful, thank you
/ Semi rural living - Fire safety & water provision best practices #29
Going well. I completely missed the part about the Home being existing. If it’s a single story I believe the install would be much easier. Two story...don’t know about that.
For an existing home, quality working smoke detectors, fire drills and common sense will be the most useful. Smoke detectors have an 8-10max year life span. They are easy to replace. The number one cause of fires where we are is lightening strikes. Second to that would be kitchen fires. Having an extinguisher handy in several places of the home (kitchen, laundry, garage, etc)is good practice. If an oven fire happens, leave the door shut and kill power.
Brett
/ Semi rural living - Fire safety & water provision best practices #30
Several have mentioned the importance of Insurance...
It has basically become unobtainable for love or money in parts of California...
There is one simple criteria... distance from public fire hydrant... nothing more or less when it comes to buying insurance. Type of construction, fire sprinklers, pond, draft pipe, water storage can be a factor in determining price.
It really has come down to this...
I looked at rural home 1 mile from a public school... the home was within so many yards of a fire hydrant and no problem.
Exactly one mile down the road I looked at another home... it had 20,000 gallons of water storage plus a draw pipe with diesel pump from the pond... well cleared, tile roof, fire sprinklers etc... no chance as far as ANY conventional Homeowner's Policy... simply not possible... oh... 4 miles from fire station and in the city limits.
I spoke with the owners and heard again the same as before... the ONLY insurance they were able to obtain was through Llyods of London... it was only to cover the Insurance Requirement of the Loan... 380k loan balance with 9k premium through Llyods.
They have another policy for liability, wind damage, earthquake, hail and liability that excludes FIRE.
What people are learning is your options are limited and/or expensive... you are very much on your own... even if in city limits...
The ranchers and farmers I know take defensible space and fire restive construction very seriously...
One insurance underwriter put it this way... you can have your own private Fire Station fully staffed and equipped... but, without a public hydrant within range there is nothing we can do for you regarding a new policy... the fire hydrant is becoming the litmus test... at least here in California.
https://www.cnbc.com/2018/01/18/after-wildfires-it-gets-tougher-to-insure-a-home-in-california.html
Wildfires push Californians to high-risk insurance market | Reuters
Homeowners in high fire-risk areas are upset over soaring insurance rates
http://www.insurance.ca.gov/0400-ne...abilityandAffordabilityofWildfireCoverage.pdf
As a side note... I know ranchers that have gotten themselves into trouble simply creating a defensible space... heck, in my city it requires paying hundreds of dollars to apply for a permit with public hearings to remove a single tree... many simply will not be proactive... had a hazardous Walnut Tree in the back yard... took 6 weeks and $225 permit fee to remove and the neighborhood was placarded with Notice of Public hearing regarding my Walnut Tree.
(APPROX. 20) 4' X...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2015 Chevy Cruze Sedan (A59231)
2015 Chevy Cruze...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A61165)
2004 Freightliner...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
2003 Dodge Ram 1500 Pickup Truck (A60352)
2003 Dodge Ram...
