SDS plus adapter to use an SDS Max bit
   / SDS plus adapter to use an SDS Max bit #11
snip
Do they make that attachment for a SDS Plus rotary hammer? ls a plus hammer heavy enough to drive a ground rod in hard ground?
I don't believe so. I looked 16+ years ago and the only ones I found were SDS Max (and they were NOT easy to find in the stores back then - before internet shopping was real big). I just rent a big hammer drill when I need to use that but do pretty much everything else with my SDS+ drill that I own.
   / SDS plus adapter to use an SDS Max bit #12
They probably don't want u to reduce the shank of a larger diameter bit ie sds max 18 mm - sds 10 mm where it connects into hammer where most force is applied . Any way it don't sound like a good idea any thing larger than 2 " should have a 18 mm shank . If u really want to try just buy the bits and weld up what u want.:drink:
   / SDS plus adapter to use an SDS Max bit #13
If anyone is reading this post and you want to drive t-posts using a sds plus spline simply buy the ground rod sds plus bit and put it over the sds max 2-1/2" driver if you don't care about using the sds max in a hammer drill again.
   / SDS plus adapter to use an SDS Max bit #14
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
2012 VANGUARD 53FT DRY VAN TRAILER (A52141)
2012 VANGUARD 53FT...
