Titan 7 foot rotary mower.
   / Titan 7 foot rotary mower. #1
WoodChuckDad
Elite Member
Free Union, VA
Kioti RX7320 Power Shuttle Cab, Komatsu PC130-6
I bought a Titan 1507 today. I was running out of daylight when I brought it home so it will be tomorrow before I take it off the trailer and will probably be next week before I test it out. I will give a full review and shoot some video when I do.
Question for the masses. It is supposed to come with ep-0 grease already in the gear box. I will check it before running it. What is EP-0 grease? What are some good brands if it needs to be topped off?
   / Titan 7 foot rotary mower. #2
EP=extreme pressure. 0=semi-solid.
It's a flowable/low temp grease that won't break apart under pressure from the gears meshing together. Check the manual and see if it calls for a specific formula of grease, lithium, silicone, etc. It may not call for an exact chemistry as long as the basic conditions are met.
As for brands...no idea.
AGCO uses EP-0 in their discbines, so AGCO/Massey dealers should have tubes of their stuff on the shelf.
   / Titan 7 foot rotary mower. #3
If you have a local John Deere store grab a case of JD corn head grease. That痴 what it was designed for, it has EP additives & NLGI-0 rated.
Nice mower too, congrats
   / Titan 7 foot rotary mower. #4
If you have a local John Deere store grab a case of JD corn head grease. Thatç—´ what it was designed for, it has EP additives & NLGI-0 rated.
NLGI-0 isn't EP-0, technically. It's a shredder gearbox, so probably doesn't matter, but they're not the same thing.
   / Titan 7 foot rotary mower. #5
I checked my 1810 when delivered and it was filled. I would still check it out to be certain.
I use JD cornhead grease. It is technically not EP-0 as stated but is a flowable grease that works fine. I've had my 1810 for almost a year now. It is a good cutter that offers a great value.
   / Titan 7 foot rotary mower. #6
Appreciate the correction. I was misinformed then by a shop mechanic and should have looked it up myself. He told me to run it and it had EP additive on the box so I took it as he said. So good to know!
   / Titan 7 foot rotary mower. #7
NLGI is the consistency rating or number, in this case 0. If yours said it was EP too, then it should be good.
   / Titan 7 foot rotary mower. #8
I'm sure it would work fine in this application.
   / Titan 7 foot rotary mower. #9
I'll be looking forward towards your review.
My dealer in Paige offered me a decent trade in for my Rhino 160 a 5' cutter.
I'm looking to upgrade to a 6' unit. Either the TW16 or the Titan six footer.
Looking at the specs the value is that it has a lower price point then the Rhino TW16.
Still prefer chain guards and slip clutch though.
Now the grease thing has my interest because the idea of needing a additive for this is all new to me.
So whatever you can share with use will be greatly appreciated.
Found this doing a quick search: https://www.cenex.com/~/media/cenex/files/lubricants/cornhead grease/corn head grease_pds-h9-02.ashx
I appreciate the info on grease.
As for the cutter review, I tend to get frustrated with not having enough info when I am looking for something. So i bought a GoPro and i am going to try to take a lot of video. And put something decent together to help out the next person who is evaluating one. I have the Chains ordered. They will be on the next truck which shows up next month. I
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2018 FREIGHTLINER...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
Peterbilt 377 Semi-Truck (A52128)
Peterbilt 377...
Livestock Oiler (A50515)
Livestock Oiler...
New 4-17.5 Forerunner Skidloader Tires (A50774)
New 4-17.5...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51243)
2021 MDB TF150R...
