CornettoTrifecta
I recently replaced/supplemented our old farm truck with a newer model. Yesterday it got its first run towing under our ownership, and we were quite pleased with the results. Here's a rundown of the specs and configuration:
Old Truck:
1988 Ford F-250 HD Regular Cab 8' Bed
7.3L IDI w/ Banks Turbo
3.55 Gears
GVWR: 8,600
GCWR 12,000
Empty Weight ~5,800
New Truck:
2017 Nissan Titan XD Regular Cab 8' Bed
5.0 Cummins V8
3.92 Gears
GVWR 8,990
GCWR 19,450
Empty Weight: 6,786
We avoided the big 3 this time around based on price and nothing comparable to the old truck available on the market. Everything in the "3/4 ton" category now is basically a rebadged SRW one ton 10k GVWR truck, which was more than I needed, and more than I wanted to pay for. This truck was used off-lease with 16k miles and ran us $29.2k - I couldn't even touch a gas F250 for that price in the local market of the same age/mileage. That was a no haggle price from Carvana and it showed up a few weeks later in our driveway hassle free. Great buying experience, highly recommended!
We ran the foothills of the Appalachians at 55-65MPH without any trouble. Having a heavy tow vehicle is great for highway stability, an often overlooked benefit of a porky diesel option, even if you lose some payload. It's still early days, but I would not hesitate to recommend this setup to anyone if it meets their needs.
What I lose with the Nissan:
Rear axle: It's a semi float 4900 lb. AAM axle. I would not recommend overloading this like you might have been able to get away with on the older 3/4 tons with a full floater.
Front axle: Independent 4900 lb. axle. It seems plenty heavy enough to handle the task at hand, but it's not a solid front axle - but my old truck was TTB and I'd take this new setup any day of the week. Those newer Super Duties though, nice solid front axles under those!
Payload: New trucks are heavier. If you need the payload you'll have to bump up to the ~10k GVWR 3/4 tons or larger. My old truck was ~2,800 payload this new truck is 2,204 payload.
Old Truck:
3.55 Gears
GVWR: 8,600
GCWR 12,000
Empty Weight ~5,800
New Truck:
5.0 Cummins V8
3.92 Gears
GVWR 8,990
GCWR 19,450
Empty Weight: 6,786
