found in toolbox new M7060-12 CAB
   / found in toolbox new M7060-12 CAB #1
RoyKing
Gainesville Florida
M7060HSC/18, RTV-X1100C
Found the radio bracket and fuse, cat 2 to 1 bushings,
A U SHAPED 1/2" HYD LINE WITH TWO DIFFERENT SIZE FITTINGS ON THE ENDS about 3 inches by 4 inches
looks like bypass for something?
   / found in toolbox new M7060-12 CAB #2
The U shaped thing is because you have a loader on and the hyd lines are hooked up. Remove the loader and lines and you have to put the U shaped thing on or pump fluid all over. You'll never use it but it's nice to have. The cat II to I bushings are needed because the link ends are cat II. It's a courtesy gift from Kubota. Classy company.
The radio bracket adapter is because of the size of radio you have. For a different radio you might need it. You never will and it will rust out before you ever need it. Toss it or toss in junk drawer.
yellow ball Trailer (A56859)
yellow ball...
183 (A52705)
183 (A52705)
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E83NKE63062, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
(2) FIBERGLASS LADDERS (A58374)
(2) FIBERGLASS...
New/Unused CFG Industrial QH12R Mini Excavator (A57453)
New/Unused CFG...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
