Why is it so hard to find durable insulated work gloves?
   / Why is it so hard to find durable insulated work gloves? #21
Why has this become so difficult? I am looking for good quality insulated leather work gloves yet any I find in stores don't seem durable and the big Amazon is full them but with very mixed reviews.
I turn to you my fellow TBN'ers, have any of you found insulated leather work gloves that really hold up to the abuse of handling firewood or farm chores without losing their insulating quality or just flat out falling apart? I'm looking for gloves that are warm down to about 20 deg F.
Please post a link if you have suggestions!
I've had two pairs of these for several years. They seem to last very well. But I don't wear them unless its below 20 degrees or so.
https://www.menards.com/main/home-d...06-c-7081.htm?tid=-8607909257065771320&ipos=4
Above 20, I don't wear insulated gloves. I just don't get cold that easily. So I wear these, which are about the same thing as above, with no insulation. I have 3-4 pairs of them and they just stay in the pockets of my different jackets. They last a good long while as well.
https://www.menards.com/main/home-d...19-c-7081.htm?tid=-8607909257065771320&ipos=6
   / Why is it so hard to find durable insulated work gloves? #22
Remember, leather can be any animal hide like cattle, pig, goat, deer, etc...
I think deerskin leather is a softer, more flexible material and lasts longer in moderate work because it doesn't crack like cow hide leather can. But cow hide is probably tougher. My brother in law only wants cow hide gloves because he says they're tougher. He's a heavy equipment operator by trade. With that said, he sits in a cab all day (how tough do you need?) and he's a cold temperature wuss. :laughing: (never waste an opportunity to make fun of your B.I.L.).
I only want deerskin or goatskin leather. It's much softer and I haven't seen any wear issues VS the cow hide leather gloves I've had in the past.
   / Why is it so hard to find durable insulated work gloves? #23
The elk skin gloves from Aerostich aren't cheap but I've had them five+ years. No rips, tears or cuts. Every year I thoroughly wash in laundry detergent and re-oil with a good brand of liquid leather conditioner. They show the stains of the years of mud, grease and use but otherwise they are still fine gloves.
   / Why is it so hard to find durable insulated work gloves? #24
I've had good luck with deerskin gloves for longevity, problem is the prices went way up in recent years and even cheaper gloves cost more.
For insulation, I found that a pair of Thinsulate glove liners inside regular work gloves is an ideal solution for temps down to about 15F. Below that I am normally doing less intense work and heavy ski gloves are OK.
   / Why is it so hard to find durable insulated work gloves? #25
I have found glove liners are the life saver for me. I have some random leather insulated gloves. They are ok down to about the freezing point. Below that throw in a pair of liners. That gets me down to zero or so. Below that all bets are off. Big ski gloves and liners come out. I am not doing much more than a quick stall muck at that temp so durability is not the prime concern.
   / Why is it so hard to find durable insulated work gloves? #27
I have never had any luck with gloves. I have bought premium gloves but never felt like I got that great a life out of them. I tend to buy those three packs of leather gloves at lowes for under $7. I happened to stop in for some and they were clearing them out for 53 cents for a pack of three. At that price I bought the last 18 sets. For a little over $9 for 54 sets of gloves I thought I did okay.
Doug in SW IA
   / Why is it so hard to find durable insulated work gloves? #28
Doug in SW IA
Gloves are consumables. If you are satisfied with the quality for the purpose at hand then good for you. Not everyone needs $40 a pair gloves. The cheaper the better sometimes.
   / Why is it so hard to find durable insulated work gloves? #29
I've never tried it, but would welding gloves work for you? They keep the heat out pretty good when handling hot metal and seam tough enough to handle firewood.
   / Why is it so hard to find durable insulated work gloves? #30
I buy the army surplus leather gloves with the separate wool liners. Usually get several sets so I can dry out some and wear another. If they wear thru they just interchange.
They aren't the warmest, but with a couple pairs of the liners they do ok.
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2019 GALYEAN...
16ft T/A Utility Trailer (A59231)
16ft T/A Utility...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
(INOP) JLG E300AJP ARTICLATED MANLIFT (A60429)
(INOP) JLG E300AJP...
