Buying Advice Heavy duty tire chain
/ Heavy duty tire chain #1
Lacmullin
Member
Québec, Canada
International
Hi, which company do the best and where is the best place to buy heavy duty chain to put on Toolcat tire.......need to be very aggressive on the ice.
Thanks
/ Heavy duty tire chain #4
The diamond shaped chain pattern with the v-bars welded into the links seem to work the best from my experience but they are very expensive. They are the most aggressive as well.
DEWFPO
DEWFPO
What is the size of the chain? Is 1/4 enough or need more like 5/16?
/ Heavy duty tire chain #7
Also, they also make regular chains that have 2x times the number of cross chains and welded in v-bars in the links. Those work well also but are even more expensive than the diamond chains.
DEWFPO
/ Heavy duty tire chain #8
In 20+ years the best chains I have ever run were Trygg from Norway. The only economical way to purchase is to pre-order for next season and if you have someone that is will to share the shipping cost even better. I have a set on my TC right now that is in its 5th year in service and I just last week broke the first cross link. I purchased from White Mountain Chains in Idaho.
Can you tell me the size off the chain link?
Thanks
/ Heavy duty tire chain #10
TRYGG has several styles and sizes of traction chains;
TRYGG Kjetting
And there is also Aquiline Talons;
Aquiline Tire Chains
And lets not forget OFA they make many styles of good chains;
OFA
/ Heavy duty tire chain #11
Unfortunately, I do not have that information here at work. There is a photo image of the 'tag' (size, etc.) from the chains posted in this section as previously requested.
/ Heavy duty tire chain #12
Thanks
I agree with Groundcover. The chains are made by Wallingfords which is headquarted in Maine. They also have a plant/warehouse in New Hampton, NH. I recently had them custom make two sets of square-cut chains without prongs for my 29x10.5x17 lugged tires. They are heavier gauge links than Pewags. And, they will not damage concrete or asphalt surfaces as much as pronged chains. However, they weigh more and cost more than some other brands. They have performed well for us this winter.
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
JOHN DEERE 4555 TRACTOR (A63290)
JOHN DEERE 4555...
BLUE TRIM LONG 8 BOX WOOD FRAME BARN (A63290)
BLUE TRIM LONG 8...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
