M7040 Hydraulic Filter Change
   / M7040 Hydraulic Filter Change #1
Treesanddust
Dallas - East Texas
Massey 65, Massey 1150, Kubota M7040
Getting ready to do the required 300 hour hydraulic filter change on a M7040.
I'm looking for information as to how much hydraulic oil I'm going to lose when I pull the old filters off.
Will I be draining most of the hydraulic oil or just a gal or two?
Thanks!
   / M7040 Hydraulic Filter Change #2
When my son changed them on our M8540, he lost about five gallons, it sure shoots out of there. Our dealer said their techs could do it and only lose a small amount, but I guess they are a lot better at it. We only lose about a quart when changing filters on our L5030.
Maybe someone else has had better luck.
   / M7040 Hydraulic Filter Change #3
For the umteenth time - just change the hydraulic oil, too.
Unless you are broke or put 600 hrs. a year on the tractor it is not that expensive. It will get rid of the winter condensation as well.
   / M7040 Hydraulic Filter Change #4
I would have to pull my Operators Manual out to check, but we pretty much go by the schedule in there and only change fluid when required as our tractors don't sit during the winter. I have spoken with the Service Manager at our dealer and that's what he advises.
If changing fluid more often makes someone feel better than that is what they should do.
Appreciate all the replies.
We go by the maintenace schedule in the manual for most things, more often for some items, so I'm not totally opposed to replacing all of the hydraulic fluid every 300 hrs.
Our Kubota dealer doesn't carry SUDT which is what we're running in it, so I have to order online and have shipped in.
Think I'll just replace the 5-6 gallons this time.
These 300 hours seemed to happen pretty quickly for some reason.
   / M7040 Hydraulic Filter Change #6
I am guessing the M7040 is pretty close to the 8540 and ours takes fifteen gallons of fluid for the transmission, so to me it makes no real sense to change the fluid twice as often as manual recommendations regardless of what anyone says. I have been operating farm equipment for well over fifty years and know of no one who uses them for a living who does this. Many farmers use their utility tractors well under 600 hours a year and still stick with the schedule if not going a bit over.
I am not broke and one of the reasons I am not is because I don't spend money needlessly, well not for this anyway. No disrespect to anyone.
If you don't want to lose any oil, you can, according to the Operator's Manual, drain the fluid, change the filters and then put the fluid back in. We decided that was too much trouble, but may give it some consideration the next time.
   / M7040 Hydraulic Filter Change #7
Seems backward to me. Book says drain fluid and replace filters at 300 hours; drain and change fluid at 600 hours. I don't have a pan I trust is clean enough to put oil in then pour back in the transmission. Did anyone ever inquire if Kubota just got this reversed?
   / M7040 Hydraulic Filter Change #8
No one mentioned using a shop vac on the filler port to provide suction to minimize fluid loss when changing filters. The vac doesn't pick up any fluid. It's worked on smaller Kubotas anyway.
HP
   / M7040 Hydraulic Filter Change #9
HP
DITTO
   / M7040 Hydraulic Filter Change #10
I would guess your M7040 will be the same as my M6040. Mine took a little over 60 US quarts - 15 gallons. I changed mine at 50 hours and will again at 600 hours. I will totally drain down at 300 hours - install two new hydraulic filters - and refill with the fluid I just drained.
BE SURE you have a single container that will hold ALL the fluid. Trying to swap out a full container as the hydraulic fluid is draining - not a pretty picture.
I intended on using plastic five gallon buckets. Then I realized how tough a full bucket was to move and replace. I have a large Tupper Ware tub that works just great.
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
TARTER CREEP FEEDER (A52708)
TARTER CREEP...
(2) FIBERGLASS LADDERS (A58374)
(2) FIBERGLASS...
2018 NISSAN Sentra Sedan (A56859)
2018 NISSAN Sentra...
PALLET BOX OF MISC (A58374)
PALLET BOX OF MISC...
John Deere 460M (A57148)
John Deere 460M...
