Clutch slipping on Case IH 275
   / Clutch slipping on Case IH 275 #1
ninjaboy
Hello everybody,
I have a 1987 Case IH 275 4wd w/manual transmission. The problem is the clutch appears to be slipping. The tractor will not move in any gear other than 1st in low range. In any other gear and any other range the tractor will not move. When the machine hooks up in 1st gear/low range it doesn't slip at all. We took the machine apart and the clutch appears to be fine. Does anybody have any ideas on what the problem may be? Any help would be appreciated.
Thanks,
David
   / Clutch slipping on Case IH 275 #2
I'm having the same issue did you solve the mystery? Thanks
   / Clutch slipping on Case IH 275 #3
   / Clutch slipping on Case IH 275 #4
Yes I see no one helped you at the time of your questions. I just bought my 275 with this same issue and found your post online. Thought I'd try asking you before starting a new post and likely not having any reply. Hope you recall something about it that can help me out. Thanks
   / Clutch slipping on Case IH 275 #5
had the same problem with my 275-----boughr it broke. took it apart the clutch looked ok put a pair of pliers on the sher pin-it pulled out in three peases. the peddel was real soft should have been the clue just saying.
   / Clutch slipping on Case IH 275 #6
I started a new post for this issue. In short it was the clutch on my 275. Thanks for the reply with your thoughts. I did see a YouTube of the same issue you had.
   / Clutch slipping on Case IH 275 #7
It was just the clutch friction plate. Working now and I have a extra on the shelf.
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
black Max power washer (A53421)
black Max power...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2025 JMR 40in Brush Grapple Skid Steer Attachment (A55851)
2025 JMR 40in...
TEST YOUR BID BUTTON! (A52707)
TEST YOUR BID...
