Square tube bender
/ Square tube bender #1
Haneyman
Member
John Deere 3038e
Want to ask the brain trust here if I can get acceptable results bending one inch steel tubing in one of those cheap hydraulic pipe benders.
Thanks,Mike
/ Square tube bender #2
Thanks,Mike
I kinda been through that same question recently. Look in U-Tube and search what you want... I didn't try any but some guys show it can be done with some success..
/ Square tube bender #3
You need a die for the tubing and the tubing may have to be thin walled. The die has sq shoulders on it where the pipe dies are round. It may work with pipe dies just give it a try. I could not get it to work as the tube would try to flatten out on the sides
/ Square tube bender #4
Those cheap hydraulic pipe benders are more like pipe kinkers.
How many tubes you wish to bend? Wall thickness? Appearance? It all cost money. For a small project fill the tubing with sand, tack caps, heat till red and bend over a radius you want. Gentle taps with hammer while hot. With a little practice not hard. Doing cold requires investment in tooling.
/ Square tube bender #5
Are you looking for a tight corner bend or just an arch in a long piece? Either way, the HF type benders won't work.
If you need an arch, you might check with fence companies that do ornamental gates; we'd often just roll a stick of metal for someone that needed X" rise in Y'.
If you need corners they might have them, or can get them with their next order from King.
/ Square tube bender #6
I made myself a bender just the other day . The tubing I was bending was very high tensile ( top rail for a garage dr. opener) but it's what I had and I didn't want to spend any money for the project just putting in time in the shop where it was warm.
You don't want any more than a 1/16" tolerance over the width of your tubing I used a 5/32 welding rod centered to collapse the inside of the tube which is necessary to keep the sides of the tube from flaring & splitting.
Only had 4 bends to make so didn't spend a lot of time being fancy making it but had good results.
/ Square tube bender #7
Billrog....those bends really came out nice...
/ Square tube bender #8
VERY NICE JOB.. all the way around.. I really like the foot rest too.!!!
What are u using for the back seat..?? factory seat?
Mine came w/ the back seat but my MAIN seat frame{wood} has rotted.. IF u were "making" the rear seat, I'd be interested in the process.{pics}
I went to a g.cart dealer & asked if they ever heard of a "poly" frame.?? They said no, just wood.. I think they just wanted to sell me a used 1 for 80.00.??
I find it hard to believe that NO ONE has come out w/ a "plastic" front seat frame to build off of.. They have them for boat seats..
Anyway> GOOD JOB..
Anyone know how to view attached thumbnails on an iPhone?
I would like to see the bender refered to but no pics are coming up.
Thanks,Mike
/ Square tube bender #11
Thanks,Mike
In this forum to go " build it yourself " "building trailer bows"
11-11-14 date. May have to search it..
/ Square tube bender #12
Nice job on making your own dies to work with those pipe benders.
Hats off to weldingisfun and billrog.
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A61572)
2025 GIYI GY-PG72C...
17109SFL (A61569)
17109SFL (A61569)
2004 PETERBILT 379 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2004 PETERBILT 379...
2022 EZ-GO ELITE...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
