Larry Caldwell
Elite Member
There's always a corduroy road. No prep, and it will last until the trees rot.
Thoughts from the Woods: Corduroy Road Update
Keep in mind, this won't be a heavily traveled road. 2/3 of it will be an outdoor storage area ("junkyard"). Does that change anything?
Assuming that does not change anything, what you describe sounds pretty costly. Would it be possibly cheaper to have a contractor come and have the whole thing? Total area is 5000-6000 square feet.
Eureka! I have been thinking and re-thinking how I should get the ground firm enough for the trucks to tailgate the road base in over the fabric without tearing it. The "best" I had come up with so far was to lay out 2x12s for them to drive on and then dig them out before compacting. Never once occurred to me that the trucks go both forward and backward, just like every other wheeled vehicle.The heavy road base fabric is the best way to go, if you can pull a few inches of mud out of the way lay the fabric down,
then have the gravel haulers tailgate it out in reverse.
I got (what I think is) a good deal on 2 huge rolls of road fabric today. The seller was a corrugated pipe sales place that I guess started trying to offer the fabric a while back and had trouble selling it. The date code on it is 2017 and it's probably been sitting outdoors since then, but seems in good shape and even if it's degraded, probably only only the first few wraps are affected. They had long rolls of thin stuff and shorter rolls of thick/heavy stuff. I got 2 rolls of the thick/heavy stuff. According to the label they're just over 200lbs, but being saturated with rain I estimate about 400lbs each
That will work. Did he sell you pins also?
