What is the best way to install a grab link onto a chain?
   / What is the best way to install a grab link onto a chain? #51
The question is getting blurred here.... In the original post its about a "Grab Link" not a "Grab Hook"...
Focus people...
Dale
   / What is the best way to install a grab link onto a chain? #52
As I read the problem, the chain links won't accept the grab link 'pin'.
What I do in those cases is to take the last chain link and either hit it with a 5 lb hammer to make it open up (hold link with vice grips) or heat it and drive a taper drift punch to open up the last link.
Then B4 it cools dip it in oil to re temper that expanded link.
Either one works 4 me.
Done that too with a punch.
   / What is the best way to install a grab link onto a chain? #53
Focus people...
Dale
Well now, the grab link can be attached by itself onto any chain link the small end fits onto.
The question in the Original post that states:
Also has to be able to move/rotate easily within the new fastener that will be mounted to the end of the chain.
Leads to the discussion about hooks.
Can a grab hook can grab a small end of a grab link? I guess we would have to try that but it would just give you a choker. :D
   / What is the best way to install a grab link onto a chain? #54
I was surprised to see the prices for Grab Links. What makes them so expensive? Or perhaps I was simply shopping at the wrong places...
   / What is the best way to install a grab link onto a chain? #55
Since you didnt mention how much you were seeing as far as pricing......
based on what the OP posted, the two from his original link is 8-12 bucks.
seems reasonable to me based on cost of manufacture, liability insurance and mark up.
   / What is the best way to install a grab link onto a chain? #57
Prices I saw were $25 - $40 each. Do you know of a less expensive site to purchase from?
Thanks.
Purchased one recently in a local store for $10. Heavy duty and nice quality.
   / What is the best way to install a grab link onto a chain? #60
I use the keyhole on my choker chains because they don稚 accidentally disconnect. I found grab hooks on chokers will unhook frequently with the roll and tumble in winching.
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
2018 BOBCAT E50 EXCAVATOR (A52707)
2018 BOBCAT E50...
UNUSED JCT DB500 DUSTLESS BLASTER (A57193)
UNUSED JCT DB500...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
2017 Ford F-350 Crew Cab Pickup Truck (A55973)
2017 Ford F-350...
