Good morning!!!!
   / Good morning!!!! #89,661
67°F and .18 inches rain.
Off to Konaside, lunch with retired military guys, Codtc, Zlowes to pick up roofing metal.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #89,662
Good morning! 58˚F and a line of Thundershowers heading this way from the West. They should be here about 7am, the same time the gardens are requesting a tractor operator for their clean-up day. Looks like we will have a slight delay this morning.
I think the winning tractor will fit in my garage if I raise the FEL and park it on a raised stand. The ceiling is 9'. I got till April 1st to figure this out.
Kyle, I hope the Dr. can figure out the cause of your high blood pressure.
Don, i already got a plan for the new tractor in my barn, so you won't have to worry about it fitting in your garage.
Got stuff to work on my floor seams, now need the motivation. Couldnt find a little roller, except a cheap plastic one that looks like it will break the first time i press on it.
My blackstone griddle came, maybe I'll season it later.
   / Good morning!!!! #89,663
CF- I am sorry to read about your sled. I am happy to assume that you were not seriously injured other than the hurt on the wallet. A kid was killed near here sledding recently; I believe he ran off trail and hit a tree. I have yet to try snowmobiling. It seems that sleds are naturally attracted to solid/fixed objects. I snowshoe; slower and usually safer. My little sailboat was naturally attracted to every non-buoy marked rock, floating log, and sunken stump on the Lake I sailed. Luckily for the boat and captain the boat had a weighted swing keel that made a lot of noise when it hit something and bounced over it.
Buppies- Thanks for clarifying which body part. There are a lot more bad body parts posted about here than the the number of posters. I get the sense that we all have ~ 3 - 4 serious concerns apiece. :( I have Popeye Arms w/o the tattoos, almost full ROM, but not much if any lifting above shoulder strength nowadays. I am really careful about chainsaw operation and only cut downed wood now. I had to retire my splitting maul; I can no longer use it w/o injury, but as a result I finally got a decent electric 5 ton splitter. It handles firewood 1/4's well, but it cycles slowly just like the owner/operator. I should have bought one years ago.
Dave- Have a good time lunching with your friends.
   / Good morning!!!! #89,664
Genie looks good. If you haven't already, check manual for max air pressure...I blow off my ZD at about 90 psi, but turn down to 30 when I get to radiator, per Kubota operator manual.
   / Good morning!!!! #89,665
BEF, I've got one of these rollers I use in the shop for bonding Formica surfaces. I think it would do well on your floor seams.
Amtico Karndean Amtico Karndean Floor & Wall Roller 18 - 24 Inch Long https://www.amazon.com/dp/B009G7PCT2/ref=cm_sw_r_cp_tai_15xCCb6XTQTA7
   / Good morning!!!! #89,666
Agreed on 30 psi for radiator. The removable screen, in front of the radiator, catches most of the grass.
I use my Echo backpack blower or Lynxx 40 volt battery blower, to blow away the worst of the grass and dust first.
   / Good morning!!!! #89,667
Thanks, might go with one of the alternative ones a little less pricey.
A heat gun would be nice also, but plan to use hair dryer.
I gotta have a roller somewhere, ive put down vinyl before, and formica... Just gotta look.
   / Good morning!!!! #89,669
16F clear sky now upper 30's for high.
Outside early feed the little critters finish cleaning off shed roof before tomorrow nasty storm arrives, gave old wood furnace darn good cleaning...whew.
Plan for today...dump rum,...
Let me know where you plan to dump it, I’ll bring jugs!
   / Good morning!!!! #89,670
I don’t know why y’all talking about that Yanmar, I already cleared a spot for it!
New/Unused CFG Industrial QK20R Mini Excavator (A57453)
New/Unused CFG...
PALLET OF WOOD & DOORS (A58374)
PALLET OF WOOD &...
4' FORKLIFT FORKS (A58374)
4' FORKLIFT FORKS...
NEW 5/16x7ft G80 Chain Sling Double (A59000)
NEW 5/16x7ft G80...
2024 8x22 Enclosed Trailer (A57453)
2024 8x22 Enclosed...
(INOP) CUB CADET SERIES 2000 LAWN MOWER (A58374)
(INOP) CUB CADET...
