Woods TPR72 3-Pt. Power Rake Overview.
   / Woods TPR72 3-Pt. Power Rake Overview. #1
Cataclysm
ok
LS4155HC
Ok, I have too many pieces of equipment. This is a Woods TPR72 power rake. Oops. :D
I searched and didn't find much on 3 pt. power rakes so I thought I would share in case anyone is looking at one. I am new to power rakes and still learning every time out. I was looking to buy a new one and got very lucky and scored this one off CL. I put new drum bearings in and added the cylinder to have hydraulic angle. I also put a new nylon tensioner block in a lubed the #80 chain.
First a few general things. I run this rake on an LS 4155HC. 55hp, cab with hydro-static drive. I think you could successfully run this 6' power rake on 30hp. Probably less just taking your time moving forward.
Next, this setup is maybe 1/2 as powerful as a skid steer driven power rake. While I can peel compacted gravel driveways, its really too hard on the machine. It just doesn't have the weight and power to regularly do that and not self-destruct. However; its a dream spreading new gravel up to 2 1/2 inch. Easy peasy and you can't beat the results. I've ran a box blade many years on a lot of projects and do fairly well with one. The results aren't even close, the power rake leaves a far superior finish grade in about 1/2 the time.
This power rake will peel hard clay, Bermuda grass ect fairly easily and of course, any type of loose material including wet or dry hard clay chunks. It eats it all with relative ease and produces a very very nice seed bed.
I am going to add some pictures along the way but first here's a couple of video's from a recent project. The first video shows the first 2 passes after the backhoe did a rough back-fill in some absorption trenches. In a few places I had to hit the diff lock to get through the trench. I'm going slow to keep from beating up my equipment and that's about the horsepower limit of my tractor when the rake digs in.
Here's the 3rd and 4th pass video. You can see I have kicked up to 2nd only occasionally hear the tractor respond to the load. I am mostly leveling the top 3 or 4 inches of loose dirt.
I will add more as time permits.
   / Woods TPR72 3-Pt. Power Rake Overview. #3
Thanks for the videos!
I'm in the market for a used power rake too. I have an opportunity to do some site repairs and this would be the perfect tool for restoring topsoil and prep for grass seed. If the opportunity becomes eminent, I think I will be plunking down the cash for a new 4 or 5ft model.
   / Woods TPR72 3-Pt. Power Rake Overview. #4
Power rakes are awesome. Too bad you are so far away, I’m selling mine in order get one that fits my new skid steer.
2019 GALYEAN...
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
