Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,783
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I built a tractor snow plow from an old Fisher truck plow. The angle cylinders were full of ancient ATF which I emptied out but I wanted to flush out the cylinders several times with tractor fluid before I allowed any to return to the tractor tank. I have 1/4" QC's on the cylinders so I can disconnect the plow frame from the SSQA plate. I did the flushing in the normal way by alternately extending one cylinder with the 3rd function button while letting the collapsing cylinder drain into an oil pan. At the end of each cycle unplug one QC and connect the other. I made this little clamp to hold the QC open so the fluid could be pushed out. Bent scrap of sheet metal with a nut brazed on it. The fluid looks gross because of all the snow I knocked down into the bucket. This little thing is probably to simple to mention here but I got the idea from a special pair of QC pliers I saw posted here a while back and thought someone may find this useful.
gg
gg
