Chains: Front vs Rear. Are front Chains bad for tractor
   / Chains: Front vs Rear. Are front Chains bad for tractor #41
I very rarely take umbrage with your posts, yet I have to strongly disagree with this comment. I can break anything, no matter how big or well built it is... and have proven that many times. :embarrassed:
It's much better to know the limitations of your machine, no matter how it's set up. If chains on front keep you from sliding into the ditch, it's much easier on the tractor than beating the snot out of it trying to ge back onto solid ground.
That's all right. We all have our own reasoning and at times difference of opinions. :drink:
   / Chains: Front vs Rear. Are front Chains bad for tractor #42
There are parts of AK that don't deal with the ice conditions we do, as a matter of fact we get as much or more snow than a large part of AK.
And there are parts that have more ice, some have more snow, some have both...
Not sure what that proves though?
SR
   / Chains: Front vs Rear. Are front Chains bad for tractor #43
SR
Nor do I, it's something you wanted to talk about I guess since you said "Maine has nothing on AK"..
   / Chains: Front vs Rear. Are front Chains bad for tractor #44
Have you ever seen or heard of someone "exploding" the front R&P without chains?
From that would you recommend people do NOT get tractors with 4WD or FWA or whatever?
I've only seen two, as stated above...
As for your second question, you must be having a DOH moment! lol
SR
   / Chains: Front vs Rear. Are front Chains bad for tractor #45
The 2019 New Holland calendar month of February shows a large cab tractor 80-100 hp with a front mounted snowblower and chains on the front only. I report, you decide.
   / Chains: Front vs Rear. Are front Chains bad for tractor #46
I have seen that setup many times. If someone needs chains on all four, it will be because the environment they reside in warrants it. No one wants to go out and spend a pile of cash for something that is a pain in the neck to install and changes the ride for the worse that's not needed.
   / Chains: Front vs Rear. Are front Chains bad for tractor #47
It's interesting how some posters just get a reputation for how "big and strong" they think they are.
(this is not directed at the immediately previous post, I came into this somewhere on the 2nd page or so)
   / Chains: Front vs Rear. Are front Chains bad for tractor #48
You put that much more politely than I am capable of doing. Some people just have to point out that theirs is bigger and better than mine.
   / Chains: Front vs Rear. Are front Chains bad for tractor #49
Tire chains on front, yes no maybe..... So last year I went the stud route....... Grip Studs Screw-In Tire Studs | Traction in Ice, Snow and Dirt | 1910T Tire Stud
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2013 FORD F-550 SUPER DUTY XL BUCKET TRUCK (A51243)
2013 FORD F-550...
2015 CATERPILLAR 573C FELLER BUNCHER (A51242)
2015 CATERPILLAR...
Parker 250 bu Gravity Wagon / Seed Tender (A50515)
Parker 250 bu...
2012 BMW 528i AWD Sedan (A50324)
2012 BMW 528i AWD...
Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K...
