A little disappointed with Kubota
   / A little disappointed with Kubota #171
Flaws are relative.
   / A little disappointed with Kubota #172
Come on Al what's next?
   / A little disappointed with Kubota #173
Agree 100%. After 156 posts no one is yet quite sure what the problem was (and no one knows whether it will return.) It seems likely to me that
1) someone other than the factory mounted the wheels on the tractor. Whoever that was MIGHT have been better advised to use large flat washers. Maybe. 2) that the buyer may not have checked the nuts/bolts for tightness after several hours of use as he should have. I've committed that mistake myself a few times.
No matter which of the many possibilities is true, I have seen no evidence here that should cause one to be "dissapointed with Kubota."
I would like to bring up that washers of large or any oversized diameter do not extend the intense clamping force of the nut very far outward beyond the nut - unless the washer is specially made. To do this the washer must be fairly thick high strength steel and somewhat cupped to extend high clamp forces to their periphery. EVERYTHING MOVES in some way in response to force. The washer flexes. Due to this a standard, even a high strength, flatwasher eases off pressure a bunch as you move out from under the nut, but its still better than any washer ending at the nut.​
A thick belleville is an expensive, but in some cases priceless way of extending clamp outward. They are flattened under the huge forces under the nut, but are still applying pretty good force out at their periphery.
   / A little disappointed with Kubota #174
rScotty....the problem is that SEVERAL times in this thread, SEVERAL people have tried to say that either kubota, the dealer, or the assembler messed up and used the WRONG parts. So ONE LAST TIME.....KUBOTA USES LOCK WASHERS.
:reading: :reading: WHEW! I am glad I never said it was assembled wrong :no: :no:
   / A little disappointed with Kubota #175
Well, actually it was assembled wrong. :stirthepot::stirthepot:
   / A little disappointed with Kubota #176
How did you determine that? I'm curious, it seems like that is still a point of contention as to what went wrong, specifically, and how? NOT being snarky, just trying to understand how we can conclude anything as fact...:confused3:
   / A little disappointed with Kubota #177
If it failed it was assembled/designed wrong. No exceptions. Never mind that OP could have had a wheel center thant had micro-cracks in it or whatever. It's never wear, fluke circumstance, or impossible to find QC issues, there must always be fault laid at someone's feet. Otherwise how can someone on the internet be right?
/s
   / A little disappointed with Kubota #178
Odds are -
Too loose
. . . For precaution the assembly spec 1st torque should be established at around 230 done in 2 stages to relieve the necessity of retightening caused by paint and metal creep.​
   / A little disappointed with Kubota #179
Odds are -
Too loose
2:30 like before the beer comes out?:drink:
   / A little disappointed with Kubota #180
Could do it later. But only if the wrench is set to the right value beforehand. ;)
2017 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
CARNIVAL KING ROYALTY POPCORN MACHINE (A58374)
CARNIVAL KING...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
2018 Ford F-150 XLT Sport Pickup Truck, VIN: 1FTEW1EP6JFD27162, Crew Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2018 Ford F-150...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Transfer Fuel Tank (A59225)
Transfer Fuel Tank...
