Smoking engine
/ Smoking engine #1
09112
N.E. Oklahoma
yanmar 3810, 48 Allis B
Recently got my 48 Allis up and going. Initially, it ran very well with no smoke. Now, upon starting, it runs clean but when it warms up it starts blowing blue smoke at idle. Smoke disappears at half throttle. I've cleaned the oil bath filter and found a mud dauber nest. Thinking this was the problem, but it never improved. Any ideas?
/ Smoking engine #2
When was the oil last changed? A simple oil change may help free up any stuck oil control rings. It sounds like oil is getting past the rings, or the valve seals and/or guides are worn.
Switching to a thicker oil may help, but may not be good for it in cold weather.
/ Smoking engine
I am using 30 wt oil at the moment and have just recently changed it. The engine sat for some years in the weather but I did a valve job on it prior to firing it up. When I initially fired the engine with 10W40 it ran quite clean. I changed over to the 30 wt after running the engine for about three hours to get as much dirt out as possible. Perhaps I should add an engine cleaner and run for 15 minutes or so and change again. The oil was super black when I changed the first time. What baffles me is that it runs totally clean cold then smokes as it warms up. Perhaps it's the expansion of the block, thus allowing oil past the oil ring. I never tore the engine down prior to installation, just took the head off to see what it looked like. There was no sideway movement in the pistons so I just did a quick valve seat job and put the head back on. Unfortunately, I fear my lack of mechanical abilities is beginning to show. So here's what I'll do next: Add an engine cleaner into the oil, run for 15/20 minutes, change to 10W40 and add a good oil additive and see if that helps. Though the engine is 70 years old, I know the person I bought it from and the tractor was never used much and then only for light work, so I have some hope that it is still in pretty good shape. I'll get this done in the next couple days and post the results. Thanks for your comments.
/ Smoking engine #4
That is what I would do. Some old timers were pretty bad about using poor quality non detergent oils.
I would do as you suggest, but keep changing it with cheap Walmart brand oil until it stays clean through a few hours of use. Then change again with your preferred oil....although new Walmart Supertech oil is 1000 percent better than the oil that was available when the tractor was built. That should pretty well clean it out.
/ Smoking engine #5
Not sure how changing the oil, over and over is going to help. Was the engine severely carboned up in the upper cylinder head/rocker arm area and oil return passages through the block (assuming it is overhead valve)?
Make sure the breather is clear and not clogged up. You should see blowby freely coming out of it.
I'd say, get some good oil in it and work it. Get it up to temp and put a load on it for a while, to see if it improves.
I'm assuming it's a gas engine, but not sure. If so, the most likely reason for smoking when warm and idling is oil getting in through the intake valve guides. Did you put seals on them?
/ Smoking engine
Hi Raspy, My second lot of oil is still dirty after about four hours of total running. The first lot came out like tar. This lot is much better but still dirty and I will take advise from 3Lfarms and use walmart stuff until it runs clean, because at 50 bucks a pop my wife is getting a bit upset at the B. Now about the seals. This is the first time I have ever seriously looked inside an engine, however, in my 84 years I have picked up a few things through life itself. That said, I wouldn't know a seal from a walrus. When I went into the head I ensured that the valves were seated properly since a professional valve job had been done some years prior but the head had been stored in a box on the back porch for years. I then put it back like it came apart. However, now that the subject of seals has arisin I will see if there is such a thing that should be added. This should be a fairly simple job by the sound of it. The breather was cleaned and mud daubers removed. Really thought that would take care of the problem. Anyhow, it started as a project and what an experience I've had. Wouldn't change it for the world. Bye the Bye, every question I had on this project was answered by others on this site so a big thankyou goes out to everyone that helped me on my way.
/ Smoking engine #7
This is a valve stem seal, it prevents oil from getting past the valve stem, which is what old seals will do and in turn cause blue smoke. 6612__66617.1464896209.500.290.jpeg
/ Smoking engine #8
Don't mean to butt in, just trying to help. Not really sure how old this post is but ....images%20(1).jpeg
/ Smoking engine #9
If the head was stored in a box on the back porch for years, then finally installed. If the head was off for years, and the engine was stored in a barn or shed without the cylinders not being protected with a good film of grease then the cylinder walls can have a very fine rusted surface on them. Upon start up the cylinders then begin to once again seat into the piston rings, but with some very fine pitting due to the rust. This could be where your oil smoking problem is coming from. Many, many tiny pockets of oil trapped in the pitting.
/ Smoking engine
Don't mean to butt in, just trying to help. Not really sure how old this post is but ....View attachment 592932
This is the first time I"ve seen a valve seal and is something my head did not have when I removed the valves. Do all engines use seals? I looked them up on "yesterdays tractors" but only got engine rebuild kits on screen for everything BUT a B. Could these be ordered as a part number or by diameter of valve stem from a local auto parts store?
/ Smoking engine
I should have been more specific. This head was swapped with another head that was mounted on an intact engine, so all cylinders were in good shape when I mounted it. I did not, however, pull the pistons to check or renew rings. Just got some thicker oil that I will use after putting an engine cleaner through it for a quarter hour and see if that stops it. Actually the smoke is no big thing because I have no interest in the tractor except to see if I could get it on it's feet again. I would like to see it run clean though. At 84 I just wanted to have something to do that I had never attempted before. I'll set it in the pasture, bring it in during bad weather, and maybe pull a wagon in a local parade. Thanks for the input.
/ Smoking engine
One other question: Being this Allis is a 48 model, could it be that a seal was not used in those days and if not can I retrofit with no damage?
/ Smoking engine #13
A quick nose-about on the web shows a complete valve kit that doesn't have guide seals, so it's likely they never had them. Any retrofit would require spring removal, and that generally means pulling the head to put a valve compressor on them to get to it, even if one could find some seals that would fit.
Probably best to just treat the oil with Sefoam and Marvel to loosen up what you can and live with the occasional smoke.
/ Smoking engine
Many older heads have to be machined to accept this type of seal. When the valve job was done, the guides could have been knurled to restore the clearances. The success of either operation will greatly depend on the condition of the valve stems. If they are well worn, success will be short lived.
FYI - If the heads are already machined for this type of seal, the springs can be removed without removing the head.
K7LN I have to say that what ever situation I have with the head at this moment, I will live with it. I appreciate the schooling though. It always amazes me how much good info one can get with a simple question. Thanks for the comeback.
/ Smoking engine #15
09112,
Everyone has made good points. But in the interest of practicality, I suggest doing just as you said. Clean it up, run it as needed, have fun with it. I don't think you should try to retrofit valve seals with the head on unless you do it correctly with the piston at top dead center, air pressure in the cylinder you are working on and are willing to do a somewhat tedious project with a limited benefit. It's likely that engine never had them anyway and it's likely the valve stems and guides are worn.
But do try to run it once in a while and get it up to full temperature to eliminate condensation and reduce internal rusting. A flap on top of the exhaust, or at least a can, is also a good thing.
Sounds like a fun toy.
Regards.
2006 Ford F-150 4.6L V8 Gasoline Engine (A61573)
2006 Ford F-150...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61574)
2021 Mercedes-Benz...
Caterpillar 143H/163H Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
case 370 glass door never installed (A61307)
case 370 glass...
UNUSED X-STAR 101"x20' LOADING RAMP (A64280)
UNUSED X-STAR...
