Which box blade for Kubota M7060?
   / Which box blade for Kubota M7060? #1
inode
Tennessee
Kubota M7060HD12
I'm looking at a Land Pride BB3584 (7') box blade for my M7060? Should I be considering another brand/model? I'll be using this to maintain a gravel drive way as well as some pruned trails.
   / Which box blade for Kubota M7060? #2
I can't find my proposal but I looked at a LP BB w/ hyd scarfires $3600,1/2"sideplates etc... wellbuilt.If you can find one that is built just as good-whynot.I bought an eight foot hyd scraper for the same money.
All new.
   / Which box blade for Kubota M7060? #3
I have a Land Pride BB2584 that I use behind my M7060. Does a great job. But then I haven't used any other brands so I cannot give you a comparison.
   / Which box blade for Kubota M7060? #4
While this model will work for you, it is not the ideal box blade for your tractor. Probably find that a 7 footer at or above 1000lbs with hydraulic actuated rippers would serve you much much better. But of course these types would be substantially more $$$.
If you have very much drive way to maintain, I HIGHLY recommend getting a land plane grading scraper (LPGS) for the majority of your road maintenance. A LPGS will typically cut your general maintenance time by half. :thumbsup:
   / Which box blade for Kubota M7060? #5
I have a titan built 7 footer and very happy so far. Seems very stout. Been using for two years.. My M6060 handles it very well..
   / Which box blade for Kubota M7060? #7
We use an HR3584 on our M8540DC as well as L5740HSTC and it works well. If I could afford it, I would buy one a bit bigger for the M, Woods makes some nice ones. We bought a 10' wheeled scraper when we were prepping home sites, so we can get by without an LPGS, but I sure wish I could afford one.
   / Which box blade for Kubota M7060? #8
I have a 7 foot Land Pride LPGS, 6 foot Bush Hog ROBB & 8 foot Rhino rear blade. By far and away - the 1100# Rhino rear blade is used most on my mile long gravel driveway.
The LPGS will smooth the driveway nicely. It WILL NOT clean out the ditches nor maintain the crown. It will not plow snow. It will not move material from here to there.
I use the ROBB to move material from here to there. I scarify the potholes prior to repair. It will not maintain the ditches nor plow snow.
The rear blade will do most all. Even move material, if you aren't in a big hurry. Plow snow, maintain the ditches, maintain the crown, smooth the driveway. It will not scarify the potholes.
   / Which box blade for Kubota M7060? #9
2014 KOMATSU D51PXi-22 CRAWLER DOZER (A52709)
2014 KOMATSU...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2011 JACK COUNTY 130 BBL VACUUM  TRAILER (A58214)
2011 JACK COUNTY...
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
PENDING SELLER CONFIRMATIONS (A58017)
PENDING SELLER...
2017 GMC SIERRA 1500 (A58214)
2017 GMC SIERRA...
