Buying Advice In the market
/ In the market #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
I currently own a B6100 that I love but Im in need of a bigger machine ( the 6100 isnt going anywhere )
I need something with a FEL and the capability of adding a backhoe attachment, Im not in the market for a 30000 dollar machine, Id like something along the same vintage as my 6100 so mid eightiesish would be nice ( but not a must )
Its simple to repair.
Need 4WD
What should I be looking for and what are the chances?
Thanks
/ In the market #2
Chances are good...if you dont need it in the next 6-12 months. Put the feelers out in the used market. Craigslist, local paper/classifieds, Tractorhouse, local dealers. Talk to your friends and let them know you are looking.
The backhoe makes it a bit tougher, my suggestion is to just get one that is subframe mounted and not 3PT.
/ In the market
No rush at all but I need an idea of what models were or have been avail that meet the criteria to do the search
I know Ill have to add the backhoe later and yes subframe mounted is a must, thanks
/ In the market #4
/ In the market #5
Need 4WD
Thanks
I think you are looking in a used market (with a very small hoe) with a wallet that will require 50%-75% more cash.
For anything at your "eightish" price, you will likely be limited to a true run out antique POS needing a lot of difficult to find replacement parts/repairs.
/ In the market
/ In the market #7
B6100 weighs 1,000 pounds bare tractor.
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
You probably want your next tractor to weigh a minimum of 2,000 pounds bare tractor. For moving dirt you need weight in the form of thicker steel for strength, weight for stability of the machine.
2,000 pounds bare tractor weight takes you into the Kubota standard L series, solid landscaping machines.
VIDEO: So you want to TRADE UP for a new Tractor? - TMT - YouTube
/ In the market #8
I think he needs to spend some time browsing the used tractor market. Over here that means Craigslist. Loaded tires on the larger b series would be well over 2000 lbs. Big enough for scooping gravel and dirt. Maybe I should include sand.
I imagine there are many dealers in Florida. Maybe someone has a deal. I suggest HST. But look around before you jump in.
/ In the market
Ok thanks. Im looking for an older something with a fel.
Everything I see looks to be beat to **** and still priced high, Ill keep looking
/ In the market
Im not in a rush and when the time comes to get serious I think Ill have a larger budget
/ In the market
Curious what you guys think of this Farm Tractor - farm & garden - by owner - sale
3800 hrs
has had a couple of clutches, one maybe 1000 hrs ago, hoses are dryrotted according to owner, some sort of a leak at the front both sides right near the wheels ( sounds like stub axles by the way he describes, dont know if tractors have such a thing.
Recently rebuilt engine by a tractor guy thats running a side show in his back yard
Guy selling it sounds decent
/ In the market
Dont know if a backhoe attachment is avail for this tractor......maybe there are just universal deals?
OK I see now they could have came with hoes
New/Unused Wolverine 45in Bucket Clip on Pallet Forks (A61166)
New/Unused...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
(2) 9.5-24 TIRES W/8 LUG RIMS (A62130)
(2) 9.5-24 TIRES...
2018 Infiniti QX60 AWD SUV (A61569)
2018 Infiniti QX60...
New/Unused 20ft Metal Farm Driveway Gate (A61166)
New/Unused 20ft...
2018 Ford Ecosport SUV (A61569)
2018 Ford Ecosport...
