Septic System Problems
/ Septic System Problems #1
TheFarmerInAdell
Gold Member
Adell, WI
Massey Ferguson 2706E, Massey Ferguson GC1705
I have a old septic system put in WWII era. Small tank (500 gallons). Last spring I started having trouble with the 1st floor toilet bubbling when a large amount of water went into the system (drain the tub for instance). It was only the 1st floor toilet, not the sink. There is no gurgling sounds from anywhere indicating the vent is plugged. In fact, there are 2 vents in the system (one tied to the 1st floor bathroom, one tied to the 2nd floor bathroom/laundry room, plus an AAV on the kitchen). The venting on the 2nd floor is new. I installed it when I added a bathroom and moved the laundry room up there with all new plumbing about a month after this trouble started. I had the system pumped when this trouble started, assuming the tank was getting full and blocking the exit to the drain field. The pumper said everything was good, and no "runback" -not sure if that's the right term, basically when he ran water from the tank into the drain field it didn't come back indicating a blockage. Also the drain field vent was dry. The bubbling starts after probably 30 gallons or so in less than a 2 hour time window, doesn't matter where the water comes from, and the bubbling always comes from the 1st floor toilet. Also, any other fixture will drain properly, but the 1st floor toilet will back up when flushed if it's gone to the "bubbling stage". I've attached a diagram of my system to give some insight. If I open the inspection cover at the piping leading to the tank the problem seems to go away indicating that the air is not escaping from the system. Why would the air escape there, but not through the vents in the roof? I'm at a complete loss as to the cause of this...
Anyone have an idea on the cause of this? I don't want to install a new septic system if I don't have to right now. I know I need a new one in the future, but I'd rather wait to install it until I have the area for it cleared first.
/ Septic System Problems #2
Your diagram may be more "intuitive" if you'd drawn 2nd floor on top, 1st floor in middle, tank on bottom and vent connections at appropriate elevation.
It sounds like a venting problem. There's also the twist that you have an air make-up valve at kitchen sink.
Any chance a vent pipe got frozen?
I sounds like a venting problem. There's also the twist that you have an air make-up valve at kitchen sink.
I would have thought a vent problem at first, but adding the 2nd floor vent didn't change anything.
It happens in summer, too. I sure hope the vent isn't frozen in summer! (it is Wisconsin, though...)
/ Septic System Problems #4
I am not a plumber but have installed and repaired several plumbing issues and I agree, it sounds like a vent issue on your 1st floor. Get somebody to make sure you're not overflowing the sink and toilet and stick a hose in your 1st floor roof vent and see if drains. Maybe being on your roof this time of year is unsafe, but it was 80-degrees here in Georgia yesterday.
Good Luck.
/ Septic System Problems #5
So it's "venting" through 1st floor toilet, even when you've run water from 2nd floor, even though you have a 1st floor vent.
So....why doesn't it vent through first floor vent? :confused3:
/ Septic System Problems #6
You replied while I was responding:)
If your diagram is fairly accurate the 2nd floor vent is not going to provide much or any venting for your first floor drains.
I will try to run a snake through the 1st floor vent.
I'd also like to be more specific, it is not gurgling (sucking water) it is bubbling (pushing air out). Not sure if that makes a difference. I would think that any air pressure built up in the system would push out the 2nd floor vent if the 1st floor vent was plugged. When I drain the 1st floor tub (down stream from the toilet) I get air bubbling out the toilet.
The vent pipe on the 1st floor is easily accessible from a ladder so I'll try a snake on it. I don't have any running water outside right now so I can't do that trick.
/ Septic System Problems #10
you may also have a partial blockage on the drain lines which is backing things up temporarily until it clears....this would force air upstream until it clears and also account for the toilet backing up....buildup over the years especially from tub soap scum and hair can slowly reduce the width of the drain line......I would pull the toilet and snake the drain to the tank if you can ......Jack
That thought had come to mind, but once again, why would the air not just go out the vent instead of the toilet? If the 2nd floor plumbing had no effect on the 1st floor toilet that would be where I would be looking right away. I'm afraid to pull the toilet because it is original to the plumbing (almost 60 years old!).
I'm not trying to dismiss any ideas, just playing the devil's advocate to get some thought behind the ideas.
/ Septic System Problems #12
If your septic pumper is correct and the leach field is working correctly then this is a blockage between the house and septic tank. I don’t believe it’s a venting issue. A venting issue wouldn’t magically start 60 years after the House was built......not sure how this went down that rabbit hole.
/ Septic System Problems #13
We have some place in our plumbing that has an occasional backup. I think toilet paper hangs up and it will back up and make a bubbling sound. Sewage will also come up in the showers, but pretty much all my plumbing is at the same level. It will also the sudden break loose normally and everything will drain all the sudden. You can hear it when it happens. I'd do something about it but we have lived there 21 years and its only happened 3 times.
/ Septic System Problems #14
tree leaves, bird or mouse nest, dead squirrel in the pipe, a bat...
Something pitched wrong can cause issues, undersize pipes can cause issues.
To the OP - did this occur BEFORE you did any second floor addition to the plumbing? And did that work make any difference to the first floor issue?
/ Septic System Problems #15
500 gallon tank and from WWII , not a problem ?
It started about a month before the 2nd floor plumbing was added. The added plumbing didn't make a difference.
The tank is concrete and the piping is cast iron. I will upgrade the system, but I'm hoping to wait a few years to do that until I have the area cleared out for the new system (moving it farther away from the house). I was also hoping to wait until I have all the work on the house done so I don't have to drive over any part of the new system when working on the house. It was pumped a year ago. I also have to run all my grey water into the system per code.
/ Septic System Problems #18
I’ve been doing plumbing for a few decades now. Yes it could be a vent issue, just like you could hear hoofs clacking, look and see zebras running down the street. On the other hand, I’ve seen too many to count, down stairs toilets gurgling that were the by product of a mainline and or septic blockage.
If the place has a cleanout at the structure pull the cap. If it’s lower than the toilet you may get sewage so use caution. Send a snake, camera and or water jet down that until it gets to the tank. Another easy check is to pull the lid off the septic. That would isolate it and verify it’s not a tank and or leach field issue.
/ Septic System Problems #19
Might just be the way the vent was installed. I'm not a plumber either, but the correct fittings need to be used and not just a regular Tee's, and how they are installed is another issue
A tank will last forever so long as it doesn't have a top or side wall failure.
/ Septic System Problems #20
The cast iron has rusted on the inside and the rust has fallen into the vent. Use the snake with a couple magnets attached to see if I am right. It has happened many times at the hospital I work at.
2018 Land Rover 4WD SUV (A61569)
2018 Land Rover...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2025 Heavy Duty Booster Cables (A61568)
2025 Heavy Duty...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
KMC 3pt 5ft Rotary Tiller (A62177)
KMC 3pt 5ft Rotary...
