Ls engine issue?
/ Ls engine issue? #41
Again I hope it's okay I used this thread since I felt it was a related failure. If anyone objects I'll be happy to start a new thread in the New Holland section.
NO! I was just kidding. Personally, I am very interested in this issue as well. Please keep us posted. The topics are related. Sorry, it's hard to show expression or sarcasm in plain text.
/ Ls engine issue? #42
I don't object because it ties right into the title.
/ Ls engine issue? #44
Sure is a lot of incorrect information on regeneration coming out. Maybe those that want to describe regeneration can start another thread.
/ Ls engine issue? #45
Well, seems I'm in the same boat. XR4155HC, 8 months/32hours old. Did some loader work moving snow, then headed back to the house. Dropped the rear blade on the way back to the house. About to he garage when the motor started spewing smoke, puking oil out of the exhaust pipe, tried to throttle down but engine would not cooperate. Dealer briought me a loaner today and took mine in for repair. Preliminary diagnosis was turbo let go. Waiting for report on damage.
/ Ls engine issue? #47
Just curious, but I am wondering if hiddenprairie with so few hours has Dino break in oil when it failed. What were your outdoor temps? For a turbo to let go most likely a material factory defect?
/ Ls engine issue? #48
Do they still use dino oil? That used to be in the past, now even for breaking-in they use synthetic in cars so why not in tractors?
/ Ls engine issue? #49
Has anybody been in direct contact with LS Corporate?
Will anybody be going to the show that can point them to this thread?
/ Ls engine issue? #50
They also very likely come from Korea with no oil in them. That would be done here and if you knew Dealers like I know Dealers :dance1:
I still think the problem is in the emissions system somewhere. I could be wrong. I could be very wrong.
And, oh yeah, a clogged exhaust system (the DPF) will smoke a turbo.
Quick
/ Ls engine issue?
From what I was told by my dealer was Thay have no oil when Thay arrive my dealer filled mine with 15w40 Rotella
/ Ls engine issue? #52
15w-40 dino oil isn't ideal but it didn't cause your problem, IMHO.
I'm still stuck on the emissions system. And maybe on it causing the turbo to commit suicide.. And I still maintain that I could be spectacularly wrong.
This is interesting to me, and should be to the rest of the Board, because those who already own, and those who might soon own, one of these tractors should know if we have to take any special care when running one in extreme cold.
/ Ls engine issue? #54
Mine is a LS Mtron 1.9 turbo tier 4 2018 model year
/ Ls engine issue? #56
I agree dino is not the best, but especially in the cold with a turbo. At least the dealer could have used Rotella T6 5W40 which is fully synthetic.
Not to pick on anyone, but turbos are a beast on their own, one cannot treat a turbo engine the same way as non turbo especially during warm-up and cool-down.
/ Ls engine issue? #57
Well that stinks. I think you and Rusty are certainly sharing the same boat.
I'm wondering if LS got a bad lot from the supplier or something else. We probably won't know what the exact failure point is on the turbo unless the dealer takes it apart.
/ Ls engine issue? #58
0F isn't extremely cold, at least for the midwest here. I run T6 and have operated it at -25F blowing snow during the last cold snap, but I wouldn't consider starting it without the plug heater. Lot's of warm up time.
Some good theories discussed and sounds like something that could possibly be dealt with with a software upgrade?
I don't get it. They know intake air temp, DPF temp, fuel temp, coolant temp (don't see an oil temp sensor). Seems like they can infer the conditions of operation if it has to do with extreme cold and not letting it regen.
/ Ls engine issue? #60
Just out of curiosity, does anyone follow LS on their FaceBook page? Any discussion on this issue?
I'm not on FB, thus the reason for asking.
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
Mobile command center (A61573)
Mobile command...
1058 (A63291)
1058 (A63291)
Adams 16T Tender Body (A63688)
Adams 16T Tender...
