toolcat battery and 4 wheel steer
   / toolcat battery and 4 wheel steer #1
laurencen
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
with the temperature here at -30C my toolcat is not starting, the block heater is working but will not crank, the battery was new 2016 bobcat brand, charged it and testing the CCA is 425Amps, what should this battery put out? boosting it starts no problem
secondly, 4 wheel steer is not aligned, with the indicator lights on front and rear it turns to the left, how is the sensor adjusted?
thanks for any comments
   / toolcat battery and 4 wheel steer #2
My G series manual says 600 CCA @ -18c (0F)
Online parts says 650cca standard and 1000cca opt
figured it was low for amps, this will be the second Bobcat brand battery that has just died in cold temperatures, this one is less than 2 years old, the last one lasted 2 1/2 years, time to look at another brand
thanks
   / toolcat battery and 4 wheel steer #4
AWS indicator lights require a dealer visit for steering sensor calibration. Are you saying the battery goes dead after letting it sit ?? sounds like a parasitic draw. will it crank with a charged battery? :confused3:
the unit will cycle the glow plugs, when the key is turned to crank I get maybe 2 turns of the motor and all power goes out for a few seconds, using cables it fires right up, testing the battery outside it reads 400 to 425CCA, had it inside overnight and charged it, right off the charger its reading 600CCA will check it later today, it will crank with a charged battery just not this one after sitting in the cold
   / toolcat battery and 4 wheel steer #6
My diesel deere garden tractor calls for a 500cca battery.
update, battery in the shop charged fully tests 630CCA, put it outside at minus 35C overnight and tests 375CCA, off for a new battery this morning
Giyi 59" Vibrating Roller (A53316)
Giyi 59" Vibrating...
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
2006 Dodge Ram 1500 Crew Cab Pickup Truck (A55788)
2006 Dodge Ram...
2017 Takeuchi TL8 (A47477)
2017 Takeuchi TL8...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
