Simple Tractor Cab
/ Simple Tractor Cab #11
Nice job. I found that breaking the wind was 90% of the battle. You don't need a lot of heat to make it comfortable, it even has solar gain on a cold but sunny day.
/ Simple Tractor Cab #12
Here are some pictures of the winter cab I built for my tractor, I have lexan for the windows no issues with fogging.
/ Simple Tractor Cab #15
Yes it is made out of wood, It is held together with pocket screws. The lexan is held on by metal roofing screws with the rubber gasket.
Before you start make sure to get the lexan first so you can build it to the dimentions of the lexan you have. I built mine then went to get the lexan from Home Depot and in the stores they do not carry 4'X8' sheets
as my front windshield is about 4'. I had to order 4x8 sheets and they were on not cheap. the front windshield is 1/4" thick and the rest is 1/8" thick I spent about $400 on just the lexan.
Sorry no build thread but here is a thread that I got alot of info from and his is really nice:
https://www.tractorbynet.com/forums/build-yourself/300638-300-00-bx25-cab.html?highlight=homemade+cab
View attachment 588191View attachment 588192View attachment 588193
Just thought I would share, I got a roof from a golf cart, welded receiving brackets for the uprights and bolted to Loader frame and ROPS. Made uprights of 1x1 1/4" tube. Bought marine grade vinyl, which wouldn't last if the unit was stored outside. If it does start to crack at corners etc I'll get some outdoor fabric to do the edges and corners. I need to add some ducting to capture the engine heat ie the old heater houses. I'm just going to have the door as over lap for now.
I blew snow yesterday in -16 C, very comfortable. I need to clean up the vinyl install yet but so far real happy for $120.
The unit will only be on for the winter.
canadianstrom: how did you fasten the vinyl to the metal frame? Also, more information about the "door". More pics would be great.
/ Simple Tractor Cab #17
Fabbed a cab for my Case 446 a couple years ago. Not really cheap. Laminated glass front and rear, lexan for the doors. Heat drom the engine blew in, comfy in moderate coldIMG_1134.JPG
/ Simple Tractor Cab #18
You can buy one of these for three hundred dollars.. Bercomac. Works for me.
I don't think I could make that work. I'm not sure if the clear plastic would be low enough in the front (blue circle in picture) to see the snow blower. But, the main problem is the back where I have circled in yellow. Since the tractor is center articulating, the cab needs to be very narrow behind the seat. For another picture of how the tractor articulates, see post #4 in this thread.
/ Simple Tractor Cab #20
I see and agree that it probably would not work well on that machine..
500BBL WHEELED...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
2015 Chevrolet Tahoe SUV (A61569)
2015 Chevrolet...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
30ft Highway Trailer Co. Lowboy (A61307)
30ft Highway...
(INOP) JOHN DEERE 450CE CRAWLER DOZER (A59823)
(INOP) JOHN DEERE...
