Clutch safety switch by-pass question
/ Clutch safety switch by-pass question #1
Raw Bone
I made a permanent by-pass for my clutch safety switch & installed it so I could start the tractor ( Jinma 254 ) without having the clutch depressed. It worked great while I was trouble shooting my starter problem.
However now that starter problem has been fixed, with the by-pass still installed and the tractor idling I depress the clutch and slide it into gear and the tractor immediately jumps forward . The by-pass shouldn't have any effect on the clutch disengagement should it ??? Any suggestions will be appreciated .
/ Clutch safety switch by-pass question #2
Is the clutch pedal or mechanism binding up on the anti-safety switch?
/ Clutch safety switch by-pass question #3
That's what I would wonder or the current problem is just coincidental check the linkage possible just needs adjustment. I have my clutch safety disabled also no problem. there are actually some videos on you tube on how to adjust the clutch on a jinma
