Cutting a round hole in fiber cement board
   / Cutting a round hole in fiber cement board #21
Start with the hole saw on the outside IN REVERSE - to score the surface before going in the correct direction. This should prevent the teeth from wandering once it bites into the Hardi. I have this siding and it is really durable, but you have to keep tapcons on hand if you ever want to attach anything to it.
   / Cutting a round hole in fiber cement board #22
Never tried that. I drill from the inside because I know where I have to be to get everything lined up. Then when I'm well into it, I might go outside to finish the hole. The pilot drill bit allows me to stay in place. I've never had a hole saw wander. I've also never had any issues with destroying the Hardie on the outside when drilling from the inside. The only reason to drill from the outside after I've started on the inside is personal comfort. It can be very awkward laying on rafters and reaching to where I need to drill the hole.
2008 Walker Diaphragm Pump (A55787)
2008 Walker...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
2014 TRAIL KING INDUSTRIES TRIAXLE RGN HG SERIES W/STINGER (A55745)
2014 TRAIL KING...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2022 Ammann 22/40 Compact Reversible Plate Compactor (A55787)
2022 Ammann 22/40...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
