   / Harbor Freight Tools that don't suck #10,941
Has anyone here used the sanding sponges? Thinking of grabbing some of those this weekend to work on a guitar body I'm building.
I have, the ones I used were pretty hit or miss. I was doing drywall and the media seemed to wear down/ off pretty quick. Went back to 3M ones and found them a lot less frustrating, didn't seem to wear out or load up as quick.
This was a few years ago so maybe the quality has changed.
   / Harbor Freight Tools that don't suck #10,942
[Sanding sponges...] pretty hit or miss. I was doing drywall and the media seemed to wear down/ off pretty quick.
My experience too. Worthwhile for sanding curves. Used wet, I went through several, they wore out faster than I expected.
I would use them for a guitar project. But if I were paying someone hourly wages I might look for similar in 'pro' quality.
   / Harbor Freight Tools that don't suck #10,943
Thanks, guys. I didn't expect them to be 3M quality, just wondering whether or not they are a complete waste of time.
Appreciate the input. I'll give them a try.
   / Harbor Freight Tools that don't suck #10,944
What’s your thoughts on the rotary hammers?
Been wanting one for a while. Main task will be concrete drilling and driving ground rods. New harbor freight opened about 30 miles away. So far it’s the closest and we’re in the city weekly. Thinking about the 1 1/8” $97 one. There’s also a 1” $82 one. Next step is 1 9/16” for $150.
   / Harbor Freight Tools that don't suck #10,945
Don't recall which one I bought but I've used it for probably 10 years off and on. No problems and it's their brand. If Iwas using it every day maybe not but Ive drilled probably 50 holes in concrete with their bits and no issues.
   / Harbor Freight Tools that don't suck #10,946
I’m curious as to how well rotary hammers work driving ground rods?
I’ll be installing some temporary electric fence in the spring in several places as we replace some cross fencing.
   / Harbor Freight Tools that don't suck #10,947
While we're on HF cutoff wheels...I always wear quality safety glasses after I had one come apart at high RPM. Could happen to any wheel.
For those of you doing just about anything in the shop, please get in the habit of wearing your safety glasses, especially if you don't wear eyeglasses. I have had too many close calls over the years. Still don't wear them 100%. I did just buy a full face shield with a flip down shade which is great for grinding and plasma cutting. I can highly recommend this one, so far...
https://www.amazon.com/gp/product/B000150J3C/ref=ppx_yo_dt_b_asin_title_o03__o00_s00?ie=UTF8&psc=1
   / Harbor Freight Tools that don't suck #10,948
Same here - don't use it a lot but works great when I do
   / Harbor Freight Tools that don't suck #10,949
The Home I recently bought has a Harbor Freight sourced First Alert 2054F fire safe built in.
I have the key but have no combination and none of the seller's relatives know the combination. It was sourced through Harbor Freight for $140
To open requires the 4 number combo and key.
Home Depot PDF Link
https://images.homedepot-static.com/catalog/pdfImages/79/7960ce4a-09dd-4953-b689-d915a9cc782a.pdf
The 4 number combo is suppose to be printed on the owner's manual which I have not been able to find.
Am I out of luck?
Is cutting through the hardened steel anchors to get it out the only option?
The manual is probably inside the safe. A good locksmith should be able to open a clunky safe like those using their listening tool.
Ron
   / Harbor Freight Tools that don't suck #10,950
I've kind of taken it as a personal challenge... so far the Safe is winning!
The other two were drilled and a bore scope inserted and the dial manipulated accordingly... took longer to drill than to open.
2000 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51242)
2000 BOMAG...
434669 (A48836)
434669 (A48836)
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
2022 NORSTAR IRON BULL 36FT GOOSENECK TRAILER (A52141)
2022 NORSTAR IRON...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
