ARNAUDVILLE
Member
I have so much stuff in radiator when I cut tall grass. I use a heater hose with low pressure to wash out radiator and oil cooler is that ok I don't want to bend fins.
I haven't done any mowing with my tractor yet but half of the year the dirt here turns to dust and the exhaust seems to kick it up from nowhere. I'm definitely going to look at rerouting the exhaust away from the ground before summer!I had a huge problem with the radiator on my 4720 clogging continuously while cutting grass & weeds. What I did to correct it was mostly aimed at keeping stuff from getting to the radiator in the first place. I stuffed the huge gap under the radiator with foam rubber. I covered all the holes on the chassis in front of the radiator and under the battery with duct tape and/or fine wire mesh. I bought a 90 degree bend to clamp on to the exhaust pipe outlet when mowing to keep the exhaust from blowing chaff forward. All of that helped immensely. It still clogs with fine stuff that comes through the grill openings, but I can usually go a whole day of mowing now before cleaning rather than 1/2 hour. I agree that an blowgun with a long thin extended tip works best for cleaning. Harbor Freight has one that works quite well.
I'm considering trying to work out a vertical stack that comes out between my loader mount and cab glass, and goes up the left front pillar of the cab to the roof. I'm planning on removing my soot cooker anyway, but any way I can think to run it would really end up being a 180 degree bend from up out of the exhaust manifold, to turn 180 deg down and back to the bottom of the cab and loader, then back up another 180 deg to go up the corner of the cab. Not really keen to put that much bend in the pipe, or sure if I can keep it from interfering with my FEL clearance.
Just to be clear, why would you want a vertical stack?
I needed to re-do my Ford 2000 rear exhaust system and it had a lot of kinks and bends and couldn't find pre bent parts to suit me. Loaded the tractor on a trailer and took it to a muffler shop. They custom made me an aluminized steel system, pipe and brackets only, muffler was already on the tractor, real sweet, 40 bucks. Might check it out.
Well mostly just to get it out from under the front of the tractor entirely. Wouldn't kick up grass, seeds, chaff and dust while mowing.
Couldn't you just turn/bend the exhaust tip sideways/horizontally so it wouldn't blow towards the ground?
