rangerfredbob
yeah, that's only for impacts. on a torque wrench you are moving along a longer arc to get the same torque reading using an extension because you are twisting the extension but that's it, force is force... on an impact the hammer is trying to rotate the bolt, if it is twisting the socket over it's limited rotation amount per cycle then it cannot put the torque in the bolt...
