fuel injector tester
/ fuel injector tester #1
mtnwings
Ellenville, NY
ford 1910 4x4 loader, MF 35, MF 60H backhoe
I just finished building my own injector tester using a porta power I bought new on ebay for $32.00. I am making it available to anyone that is somewhat local. It is set up for Ford 1910 injector but I am sure it will work with any Ford injector. I do not know how to post photos on this site, can anyone give me any suggestions on how to post photos?
/ fuel injector tester #2
To post pics/graphics, go from "Quick Reply" to " Go Advanced" editor below right and scroll down the screen to "Manage Attachments" and its sort of intuitive from there, pretty typical of how most sites upload and display attachments... There you will see "Add Files" and some other features (Drag & Drop) to get pic's from archive and place online....
Dale
/ fuel injector tester #3
IDK about u, but it is MUCH EASIER to just buy a pop tester off ebay..
AND it comes w/ the 2 most common line sizes to fit 80-90% of the injectors. 12 & 14mm
& not to be "snooty" but what good is having a pop tester if u don't know the correct opening pressure?? they're all different & how are u gonna change it if its off.?? {shims}
IDK???
Gee, I hope I did not step on your toes because you do this kind of stuff for big money, didn't mean to upset you, I just cant afford your services. and the shipping both ways. If need things, I figure out how to make things I need. This site is about helping others that need help and learning from others. My tester cost me $50.00 to make, I had most everything else besides the $35.00 pump I bought. The way I made it I can still use the pump for it's original purpose. I love figuring things out, building things and learning how to use them. I know my pop pressures and I have shims. My bad injector I asked about? I fixed that with a suggestion from someone on this site about using tooth past and lapping the nozzle in like I am lapping in a valve. and it tested fine after that. Thank you very much. I have other equipment with injectors so having my own is nice, one more tool in my quarry. This "build my own tester" was very rewarding and fun. Besides, it kept me here instead of going home, eating too much and watching TV wondering if I can afford to send my injector out and have someone else do what I know I can do myself. OK, I have other things to design and build, gotta go. smile Dude.
/ fuel injector tester #5
I hear ya.. anyone w/ multiple pieces of equipment should own a pop tester..
Toothpaste?? that's a new one.. lol
I don't charge to pop test injectors.. I do it for free.. & I only charge for the bottom & return gaskets, unless of course the nozzle is toast & a new one is required to make it work correctly.
& your right..the biggest cost IS the shipping..
you didn't step on anyones toes.. just like u said, we're here to help.. & God knows, I have enough work for 2 of me..lol
/ fuel injector tester #6
Please dont forget to post the photos, if you have already done so I cant see them.
/ fuel injector tester #7
It's a nice gesture, but I'd like to see it in operation first. Pop testers don't work the same as hydraulic jacks or porta-power pumps. I'd like to see your tester in operation.
To attach pics, just look at the bottom of the posting window you write in. Click "Go Advanced". Then find and click on "manage attachments". That opens a window that says "Add Files". Then "select file", and find the picture on your desktop or hard drive files. Click on it's file name below the picture. It will appear in the small window you previously opened as a file name. Then "upload". Then click "Submit Reply" from just below where you are writing. Done.
/ fuel injector tester #8
I tried to ask this question earlier but I guess I didnt do it right, can someone please explain what a pop tester does and how it works?
Thanks,
RDG
/ fuel injector tester #9
A pop tester is a tool that hooks up to an individual fuel injector, on the bench. It has a hand lever that pumps fuel to the injector, one stroke at a time, and a gauge that measures the pressure.
This gives you a way to measure several things that the injector must do.
First, it must not dribble fuel with low pressure going into it.
Second, when it does begin to spray, that is called it's "pop" point. It should hold without leaking and then pop open at a designed pressure.
Third it should have a very defined spray pattern with excellent atomization.
You can look up the pop point of specific mechanical injectors and check to make sure they do not dribble. And then see the pattern they make.
This is a tool used on mechanical injection systems, not common rail.
By pumping the handle, you can repeatedly hit the pop point and repeatedly see the spray pattern.
That is why I said the hydraulic porta-power pump is not suitable for this operation. You don't slowly pump it up, like a jack and then release with a valve. You keep firing it over and over to see how it responds. With a hydraulic jack type pump, as soon as the pop point is reached, the pressure is immediately gone. With the pop tester you can initiate the spray and keep it going long enough to see it well while maintaining a high pressure.
It's a much closer simulation to what happens with the engine's injection pump.
All of this testing reveals the condition of the injector and tests it after rebuilding it. Old ones might begin to get a bad pattern or poor atomization. Water in the system can cause corrosion and dribbling, or a broken tip, as water does not go through fuel injectors very well.
If a tip gets blown off it will send in a unatomized stream that will cause puffing black smoke, hard starting and can burn a hole in the piston. With excellent atomization, you probably won't see continuous black smoke until about 75% of the rated horsepower. At medium power levels you might get some light brown smoke showing good combustion.
/ fuel injector tester #11
I did answer your question but IDK what happened to it?? UNLESS u asked it on a diff. thread & my answer is over there??
Raspy's got it..
/ fuel injector tester #12
Thank you for that most excellent and detailed explanation, I understand now.
/ fuel injector tester #13
Thank you, I found your reply in my email but not here on this post. I think I am doing something wrong.
2019 John Deere 700K LGP Crawler Dozer (A61166)
2019 John Deere...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2022 Ford F-150 Pickup Truck (A61568)
2022 Ford F-150...
