2810 heavy Smoke
/ 2810 heavy Smoke #1
tpsball
03 mahindra 2810
Hi, I have a 15 year old 2810 that started smoking badly a couple Weeks ago, heavy White/Gray Smoke, smells like Fuel. I cracked the injector nuts and the first 2 almost stalled the engine, the back injector had no effect when I cracked the nut, so I figured it was a bad injector? Today I replaced the injector and it did not make a difference!!! I don稚 believe it痴 running on all 3 Cylinders and doesn稚 heat up at all. Anybody have any suggestions? Thanks in advance.
/ 2810 heavy Smoke #2
Gelling cold fuel.......
Btw- a diesel makes almost no heat when it doesn’t have a load on it.
/ 2810 heavy Smoke
When this startedI noticed my Son had run it real low on fuel, so I cleaned out thee fuel filter, checked and cleaned the air filter, and filled it up with Kero and Diesel 50/50. Why would all signs lead to a bad injector and then when replaced it did nothing? im missing something here, Glow plug?
/ 2810 heavy Smoke #4
If this engine has a CAV DPA inj. pump on it.??
That pump is a rotary pump & has 1 pumping unit for all the cyl.'s, so its unlikely to be the inj. pump..
{inline pumps have individual adjustments for each cylinder}
& u say u swapped injectors & still the problem remained on THAT cyl.??
Sorry to say but a compression test is in order.. at the very least u should remove the valve cover & check the valves & push rods..
Might be something as simple as a valve setting or bent rod..?? let us know how u make out..
/ 2810 heavy Smoke
Oh boy, that's way above my level! One more thing, I hear a lot of air blowing on the right side of the engine, I need to look into this before I take it to an Expert.
/ 2810 heavy Smoke #7
Blowing out the side of the engine, not firing on one cylinder, sounds like a head gasket gone. Have you checked the water colorant level and checked theres no water in the sump oil. One thing for sure, its not going to get better without a bit of help, but could get a lot worse.
/ 2810 heavy Smoke
Ok, I went out and fired it up again, something was telling me it is a fuel problem?? While it was running I popped the radiator cap and it was blowing coolant out the cap! This was enough for me to drop the blower and bucked and pull it into the garage and start the disassembly of the upper end. As soon as I pulled the valve cover and it was coated with a milky coating my first suspension was getting clearer. Soon I pulled the head and with coolant on the back piston and a crack in the gasket confirmed I have a bad head gasket! Now to find new gaskets, thanks all for the input
/ 2810 heavy Smoke #9
So much for being "something simple" but at least u found the problem.. lets hope.
Do yourself a small favor & measure the thickness of the gasket.. then measure the new one..
/ 2810 heavy Smoke #10
I would guess that the old gasket would be thinner than the new gasket because it has been compressed after being installed, fired and run through countless heat cycles........how will those measurements help the OP?
Thanks in advance for the schooling! :eek:
BarnieTrk
/ 2810 heavy Smoke #11
Hopefully you had the head rebuilt or atleast planed. If all you did was replace the gasket then the initial problem might come back sooner than later. You also need to do a complete engine oil service. Antifreeze mixed in with engine oil will damage your lower end bearings in no time. Hopefully all is well? Dutchy
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
