Glow Plug Circuit (do I need a resistor?)
/ Glow Plug Circuit (do I need a resistor?) #1
rszimm
Ford CL65
I'm fixing up an old Ford CL65 skid steer. Most all the non-essential wiring / gauges / switches were stripped out of this thing including the original ignition switch and the entire glow plug circuit (old owner just squirted a bit of starting fluid into the air filter whenever he wanted to go). From what I can tell from the schematic the ignition switch turns counter-clockwise to engage the glow plug circuit. When the indicator "glows red", you then turn the key clockwise and start the engine. The glow plugs are the pencil type wired in parallel. Here's an image of the ignition switch schematic and this mysterious "glow indicator": e7ZDYVwl.jpg . So here's some questions:
1. Whats happening inside the ignition switch with respect to terminals #19 & #17? (the extra wire off of #17 goes to the plugs). I'm thinking that in "pre-heat" mode terminals 30 and 19 are connected, but then what's #17 for?
2. I was going to bypass the indicator completely. I don't really see it as particularly useful, but it occurs to me that it may be providing some resistance and thus dropping the voltage down below 12V. Can I delete this indicator?
Just some additional info: There is no block mounted "block resistor" in this. The wire you see coming off terminal 17 goes directly to the plugs. They're all wired in parallel. I pulled them and they all seemed burnt, so I just ordered some NKG Y-107V plugs
/ Glow Plug Circuit (do I need a resistor?) #2
Hopefully you'll get a better answer than mine because I'm only guessing.
I would think the preheat is just a simple thermal device so with ignition switch switched over it supplies power to glow plugs until preheat device opens.
On NKG site those plugs specs says 10.5v which to me should be ok on 12v, but you may want to call them.
Here's the # to NKG...888-800-9629
Me, I would want to put it back stock if not too expensive.
/ Glow Plug Circuit (do I need a resistor?) #3
I don't really know what you have.
What is the indicator. A lamp or a heating element? Some Bolens type tractors had a dash mounted Element in series with the glow plugs. It would tell you what was happening. If it glowed hot, you knew the glow plugs were as well.
Others (like my Steiner) have a light, that is on a timer, but has nothing to do with the glow plug circuit. It's just a timer for the operator to watch.
Then, My mule has a timed glow plug curcuit that has an indicator light to show when the glow plugs are on and off (ready to start) and it does this every time, whether you need them or not.
So, there are a number of different systems in use.
Generally speaking, a cold 12 volt battery has limited power and reducing the glow plug power with a resistor that drains your battery and heats the great outdoors is not really a great idea.
/ Glow Plug Circuit (do I need a resistor?) #4
/ Glow Plug Circuit (do I need a resistor?) #5
It's actually a brilliant, simple, almost primitive idea. You are loosing a bit of stored energy needlessly, but knowing exactly what is happening with your glow plugs is probably worth it.
/ Glow Plug Circuit (do I need a resistor?) #6
You can wire directly with a HD switch (curent is high) and simply count off a few seconds and repeat if not successful.
(I knew one guy that simply had the 2 wires in his cab and simply held them between his fingers and counted)
Generally the plugs should be in parallel and grounding is via the engine block.(you will note all the plugs will be on one HD wire or buss strip)
Various timing mechanisms are generally incorporated to eliminate human error but the simple switch can do the job.
Just don't power up too long as U can burn out those glow plugs. Start off with, say 8-10 seconds and repeat if necessary or add a few more seconds next time.
/ Glow Plug Circuit (do I need a resistor?) #7
I had a VW Rabbit diesel pickup in '82, 4 cylinder, and glow plug light would be on about 10 seconds then off, ready to start.
When it got hard to start over the years I used an inductive ammeter on each glow plug wire to see which was open (bad ).
Then I realized all I had to do was turn key on then off 2-3 times cycling plugs on then quickly feel them. Warm ones ok...cold were bad.
On that one I would at least wire in a light, that #17 to glow plugs , wire light there to ground. That way you know they're getting power and how long they're on.
So I do not know what is supposed to be there. Nearly all the electrical was removed from this unit. The glow plug circuit ended with a cut wire. The ignition switch was replaced with a cheap key switch he picked up at Autozone. He started it by puffing some starting fluid while cranking.
I am trying to get the glow plug circuit back together. I was planning on just wiring the circuit through a push button directly to 12V, but the whole indicator thing threw me and made me think it had more purpose than just giving feedback that the circuit was working. So I guess my question is if I can simply wire the plugs directly through a push button or do I need to find a new indicator (parts for this beast are nearly impossible to find)
/ Glow Plug Circuit (do I need a resistor?) #9
Maybe call NKG who can tell you how long they can/should be on. I'm thinking your best bet would be to wire in that device DL posted, it looks like a high current glow plug light assembly made for them.
NKG can also tell you current draw.
A Ford site (V8 truck) said "all 8 draw about*190 amps, so figure each one would draw almost*25 amps."
So a 4 cylinder would be about 100 amps, so you would need a hefty switch and wire, although they're not on long.
/ Glow Plug Circuit (do I need a resistor?) #10
it seems to me that the previous owner was whacked, maybe from a head injury, or drug use. you don't go and remove all the electrical wiring from a device, unless you are scrapping it!!.. every bit of that wiring served a valid purpose, and it will be very hard for a non Engineer to restore that wiring, unless the full wiring harness with all the switches and gauges are purchased. yes, the indicator needs to be wired in, but, you also need the relay for that amount of current, 100 amps total?. then you still need to worry about engine RPM, and oil pressure.. it's a real mess you have!..
So here's some news. It appears that the engine that's in this thing is not the engine it originally came with. I was having a **** of a time trying to find things on the parts list that lined up with what was there. I finally managed to get a blow up of the block, and it appears there are differences (the oil pan looks completely different). I thought it was very strange that the oil drain plug wasn't aligned with a hole in the bottom of the unit, so opening it would create quite a mess.
So now I'm stuck trying to figure out what engine I have! I can't find any markings on the block other than an "S2" in the block casting, and what looks like a serial number P11061 stamped on the other side. Nothing else seems to have identifying marks on it (albeit it's really hard to get in there). Is there any group out there that I can post pictures to and hope to find out what engine is in this thing?
/ Glow Plug Circuit (do I need a resistor?) #12
A simple push button with relay to connect 12 volts to glow plugs would be simplest... If Autozone universal ignition switch is working why change it unless you are doing antique restoration.... Might consider putting glow lamp in circuit just in case its a inline resistor to drop voltage and it would also indicate GP's were getting power... Also agree it would be good to know what voltage/amperage requirements of PG's are...
MY new model MF GC 1715 just says to hold switch in glow plug position for 8-10 seconds.... IF I hold it longer they just get hotter... No timer, no magic, just indicator lamp on dash panel that comes on when key in GP heat position....
There is a thing out there called "KISS" principle (Keep It Simple Stupid).... Grin!....
IF engine is not original, just make thing work simplest way possible, create circuits that are needed as simple as possible...
Been doing automotive and electronics since the 60's... This circuit still has me worried though....
Dale
/ Glow Plug Circuit (do I need a resistor?) #13
Love it. Should work, as I see the inclusion of the FLUX capacitor. Does one need to buy smoke seperately for the "most expensive chip"
/ Glow Plug Circuit (do I need a resistor?) #14
A simple pushbutton and relay will work. You need a relay with 100 amp contacts and 1 gauge wire though. You could branch off to each plug with 8 gauge.
That is nutty the previous owner stripping wires, but maybe he knows what the motor is. You need to know oil capacity, filters, etc.Glow%20plugs.jpeg
That is nutty the previous owner stripping wires, but maybe he knows what the motor is. You need to know oil capacity, filters, etc.View attachment 588611
He is as perplexed as I am. It was like that when he bought it. He is going to try and contact the person he bought it from, but I am not holding my breath. I am really hoping someone will recognize the engine from the pictures in my other thread.
/ Glow Plug Circuit (do I need a resistor?) #17
Ok, so bit of a bump to this subject and back on subject. firstly "industrial toys" post describing the simplicetally of this indicator i have to agree with. being from an electrical background with experience in generator and motor protection and thermal overload devices they operate precisely as he explained.
my issue is on our walker zero turn the glow indicator has no lens on it enabling a path for moisture to get into the electrical cavity where the hour-meter, gauges, key-switch etc reside. does anyone know if there are caps that can go over the top to keep the weather out of this enclosure? this is even exacerbated as the panel faces upwards.
for reference this is the style of the indicator,
/ Glow Plug Circuit (do I need a resistor?) #18
I wonder if Pyrex has a shape that would work? I suspect that indicator gets hot, so maybe mount the lens with hi-temp silicon gasket sealer?
Pyrex makes small glass items: petri dishes, shot glass size beakers, and watch glass.
How many amps do they take? I've typically seen the ig. switch circuit activate a remote relay to handle the glow plug current draw.
/ Glow Plug Circuit (do I need a resistor?) #19
its not so much the amps that determine the heating but watts, however amps are one componant of that, i guess i need to measure the voltage drop across it whilst glowing to determine this, but regardless your suggestion of an off the shelf pyrex item may fit the bill. will have to keep eyes peeled. in the meantime i are waiting for a replacement keyswitch to come and the machine (walker zero turn mower) also needs some attention in the fuel shutoff solonoid curcuit.
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
CASE 105C (A62177)
CASE 105C (A62177)
2023 John Deere 6120M Tractor (A63109)
2023 John Deere...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2007 TEREX ADVANCE MIXER FD3000 AWD 6X6 FRONT DISCHARGE MIXER (A59910)
2007 TEREX ADVANCE...
