Universal 3pt linkage.
/ Universal 3pt linkage. #1
fire03885
Stratham, NH
Mitsubishi MT180 HMD
Hello,
I posted this in the model specific area but maybe better here?
Brand new to tractors and I recently purchased a Mitsubishi MT 180HD compact tractor (1985 with loader and 1100 hrs on it). It did not come with a 3 point hitch setup. I have seen a few linkage kits but want to make sure I get one that is right for the tractor. For example, some lift bars are 27", some 31" and some straight and some bend outward (and then back) to make a wider space. I am currently looking at this kit on eBay:
http://bit.ly/17okEPV
This has 31" lift bars that bend outward. My main attachment, at first is just going to be a lift bar with 2" receiver. But do want it to be able to be used for other attachments (blades,rakes,tiller/etc).
Just want to make sure I understand more before pulling the trigger on it.
Thanks
Derrick.
/ Universal 3pt linkage. #2
Hi Derrick,
Did you finally came up with a solution and the right 3 points linkage ? I am in the exact same situation today, with the tractor I bought, and was wondering if you could communicate the link/reference of the linkage you find / installed successfully. Thanks !
/ Universal 3pt linkage. #3
Hello,
Thanks
Derrick.
The link you provided just took me to a generic ebay web page.
/ Universal 3pt linkage. #4
I have not seen many post here that are related to Mitsubishi.
I can not answer your question, and I do not know if the parts books would show any sizes. They should show if it is straight of bent.
/ Universal 3pt linkage. #5
I can tell you that the length issue I have had are, too short and the implement can hit the tires or the draw bar when lifting.
Too long and you lose lifting capacity.
If it were me I would go with too short. Because if it is too short you can always and the Pat's Quick Connect system to make it longer, and I think you will be glad you got the Pat's system.
/ Universal 3pt linkage. #7
I have 2 Pat's Quick Hitches.
1 Cat 1, and 1 Cat 2.
I am guessing they only add 2 to 3 inches.
/ Universal 3pt linkage. #9
Your tractor.. I can not see anything bigger than Cat 1.
Anyone who ever uses any Cat 2 implements, IMO should consider getting the Cat 2 QH and bushings to make all the implements Cat 2.
/ Universal 3pt linkage. #10
Silly me.
I need to pay closer attention.
Alway a day late and a dollar short.
Thanks
2011 Honda Civic Coupe (A61574)
2011 Honda Civic...
2024 Bobcat T740 Track Loader (A63109)
2024 Bobcat T740...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
2022 Timpte 1420 All-Aluminum Equipment Trailer (A63118)
2022 Timpte 1420...
iDrive TDS-2010H...
HEIN-WERNER 1TON TRANSMISSION JACK (A63569)
HEIN-WERNER 1TON...
