Glow Plugs...
/ Glow Plugs... #1
moship
PA
Kubota L3130 HST 4x4 Kubota L4740-3 HST
Recording this info in the event it helps anyone down the line.
Summary:
Glow Plugs: 19077-65512, 19077-65511, 19077-65510, 1J860-65510, 1J860-65510, 1J860-65511, 1J860-65512 are all linked as similar using Kubota's Illustrated Parts and Messick's.
GP price is different depending on PN. Surprising given they are functionally the same.
Kubota 19077-65512 is actually a NGK Glow Plug Part number: Y-716RS, stock number: 4693 (Rockauto has them for <$15)
GP Nut size: 7mm
GP itself: 12mm (deep socket)
NGK Data: https://www.ngkpartfinder.co.uk/files/NGK_Glow-Spec.pdf
The long story:
My tractor seemed to take a bit longer to start when cold (30F and below) than I thought it should. My expectation is it starts within 2-3 seconds of crank time. Anything longer seems unacceptable. It has always started, but I always questioned if the glow plug (GP) circuit was operating as designed and I questioned the short on time the dash calls for the GP to be energized. So it was time to investigate if all is functioning as it should with respect to the GP circuit.
Started by ensuring the battery is fully charged. Battery terminals and connections cleaned using a wire brush or sandpaper to ensure good metal to metal contact. Fuel is recently purchased and Power Service (white) and biocide added every time.
To measure supply voltage to the GP buss bar the GPs must be removed from the circuit. Otherwise you will not see battery voltage on the meter. On cab tractors there is a wire connector that can be disconnected and voltage measured at that point. (See photo) Great battery voltage is confirmed to the GPs.
Accessing GPs:
The nuts used to hold the buss bar to the GP are 7mm. They can all be accessed and removed using 1/4 ratchet with short and longer extensions. To keep from losing the nuts, a rare earth magnet was placed on the socket. Nuts are the flange type with knurling on the buss bar side, so no lockwashers are used. In some instances it was easier to access the GP's from the muffler side (left side).
With the buss bar removed from the GP the resistance can be checked against spec. Great all four are similar each other measuring approximately 0.9 ohms (within spec according to WSM).
To visually inspect one GP was removed using 12mm deep socket. The GP looks to be in great shape. Sheath is clean, no blister or other overheat indications, terminals free of corrosion. Feel good about the appearance. Confirmed resistance again while it was removed. (Reference photo)
Decided to hook up the GP to fully charged battery to see how long it takes for them to glow. Wow! It takes approximately 4 seconds (at most) to see a very nice glow at the tip. Now I feel a lot more confident the short GP dash indication is justified.
Put everything back together and it starts as it should... Maybe a bit quicker - possibly due to the clean electrical connections or just a placebo effect.
I really didn't find anything, but there was some evidence of slight corrosion at the GP buss bar white connector (maybe on cab models only), and it never hurts to clean the battery terminals including the chassis side of the battery ground. It does give me more confidence knowing the GP circuit is working as it should.
Tractor Model: L4740-3 HSTC
The stock Kubota glow plug (19077-65512) is actually a NGK part number: Y-716RS, stock number: 4693 (see photo). For reference: Kubota $31.71 Rock Auto $ 15.54
NGK can also be found at Napa or others. If you can't find it using the NGK part number, use the stock number.
In researching the current glow plug part number, I found a number of Kubota GP's are interlinked.
19077-65512 replaces 19077-65511 (Messick's) & 19077-65510 (Kubota's illustrated parts show 66512 = 66510)
Using 19077-65510 was replaced by 1J860-65510 which was replaced by 1J860-65510 $21.79 (Used Messicsk's to research 19077-66510)
1J860-655110 was replace by 1J860-65511 replaced by 1J860-65512 (Messick's)
The Kubota P/N (19077-65512) is used on the following models (according to Messick's great website).
The part fits the 90 models listed below:
KJ-S130D-USA, KJ-S150V-USA, KJ-S150VX-USA - 120601 NOZZLE HOLDER AND GLOW PLUG, KJ-S150VX-USA - 120602 NOZZLE HOLDER AND GLOW PLUG, KJ-T210V-USA, KJ-T210VX-USA - 120601 NOZZLE HOLDER AND GLOW PLUG, KJ-T210VX-USA - 120602 NOZZLE HOLDER AND GLOW PLUG, KJ-T270F-SW-USA, KJ-T270FX-SW-USA - 220601 NOZZLE HOLDER AND GLOW PLUG, KJ-T270FX-SW-USA - 220602 NOZZLE HOLDER AND GLOW PLUG, KX121-3ST (SN : 70000- / Super Series / Tier 4), KX161-3ST (SN : 70000- / Super Series / Tier 4), KX91-3S2 (SN : 40000- / Super Series / Tier 3)
L2800DT / HST (Dual Traction 4wd / Hydrostatic Transmission), L2800F (2wd),
L3200DT (Dual Traction 4wd), L3200F (2wd), L3200H (Hydrostatic Transmission),
L3240DT / GST (Dual Traction, 4wd / Glide Shift Transmission / Rops / 2007 - 2009), L3240DT-3 (Dual Traction 4wd / Rops / 2010), L3240F (2wd / Rops / 2007 - 2009), L3240F-3 (2wd / Rops / 2010), L3240GST-3 (Glide Shift Transmission / Rops / 2010), L3240HST (Hydrostatic Transmission / Rops / 2007 - 2009), L3240HST-3 (Hydrostatic Transmission / Rops / 2010), L3240HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009), L3240HSTC-3 (Hydrostatic Transmission / Cabin / 2010),
L3400DT / HST (Dual Traction 4wd / Hydrostatic Transmission), L3400F (2wd)
L3540GST (Glide Shift Transmission / Rops / 2007 - 2009), L3540GST-3 (Glide Shift Transmission / Rops / 2010), L3540HST (Hydrostatic Transmission / Rops / 2007 - 2009), L3540HST-3 (Hydrostatic Transmission / Rops / 2010), L3540HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009), L3540HSTC-3 (Hydrostatic Transmission / Cabin / 2010),
L3700SU (Hydrostatic Transmission, 4wd / Special utility), L3800DT (Dual Traction 4wd), L3800F (2wd)
L3800H (Hydrostatic Transmission),
L3940DT / GST / HST (Dual Traction, 4wd / Glide Shift Transmission / Hydrostatic Transmission / Rops / 2007 - 2009), L3940DT-3 (Dual Traction 4wd / Rops / 2010), L3940GST-3 (Glide Shift Transmission / Rops / 2010), L3940HST-3 (Hydrostatic Transmission / Rops / 2010), L3940HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009), L3940HSTC-3 (Hydrostatic Transmission / Cabin / 2010)
L4240DT / GST / HST (Dual Traction, 4wd / Glide Shift Transmission / Hydrostatic Transmission / Rops / 2007 - 2009), L4240DT-3 (Dual Traction 4wd / Rops / 2010), L4240GST-3 (Glide Shift Transmission / Rops / 2010), L4240HST-3 (Hydrostatic Transmission / Rops / 2010), L4240HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009), L4240HSTC-3 (Hydrostatic Transmission / Cabin / 2010)
L4400DT (Dual Traction 4wd), L4400F (2wd), L4400H (Hydrostatic Transmission)
L45
L4740GST / HST (Glide Shift Transmission / Hydrostatic Transmission / Rops / 2007 - 2009), L4740GST-3 (Glide Shift Transmission / Rops / 2010), L4740HST-3 (Hydrostatic Transmission / Rops / 2010), L4740HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009), L4740HSTC-3 (Hydrostatic Transmission / Cabin / 2010)
L48
L5040GST (Glide Shift Transmission / Rops / 2007 - 2009), L5040GST-3 (Glide Shift Transmission / Rops / 2010),
L5240HST (Hydrostatic Transmission / Rops / 2007 - 2009), L5240HST-3 (Hydrostatic Transmission / Rops / 2010), L5240HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009), L5240HSTC-3 (Hydrostatic Transmission / Cabin / 2010)
L5740HST (Hydrostatic Transmission / Rops / 2007 - 2009), L5740HST-3 (Hydrostatic Transmission / Rops / 2010), L5740HSTC (Hydrostatic Transmission / Cabin / 2007 - 2009), L5740HSTC-3 (Hydrostatic Transmission / Cabin / 2010)
M5140DT (Dual Traction 4wd / Rops), M5140DTC (Dual Traction 4wd / Cabin), M5140F (2wd / Rops), M5140FC (2wd / Cabin), M5140HD, M5140HD (Hydraulic Shuttle, 4wd / Rops), M5140HDC, M5140HDC (Hydraulic Shuttle, 4wd / Cabin)
M5640SU (Special utility 2wd), M5640SUD (Special utility 4wd), M5640SUD / SUD-1 (Special utility 4wd)
M59
MX4700DT (Dual Traction 4wd), MX4700F (2wd), MX4700H (Hydrostatic Transmission),
MX5100DT (Dual Traction 4wd), MX5100F (2wd), MX5100H (Hydrostatic Transmission)
R420S
R520S - 020602 NOZZLE HOLDER AND GLOW PLUG, R520S - 020603 NOZZLE HOLDER AND GLOW PLUG
U35-S2 (SN : 40000- / Super Series / Tier 3), U45ST (SN : 70000- / Super Series / Tier 4)
/ Glow Plugs... #2
Whatever it is , you must have it covered.
My only comment is that 2-3 seconds is an unreasonable expectation for glow plug time in colder weather. At least with smaller Kubotas the glow plug time "on" needs to be 5 or 6 seconds at 30 degrees OAT in order for a responsive start. Maybe even a little longer on the plugs. Now granted, you can run the plugs less time and crank the engine more and, yes, it will start grudgingly and slowly. I see the smoother approach is to run the glow plugs long enough such that the engine starts quickly and effortlessly when it does crank.
/ Glow Plugs...
Thanks for the feedback...
The 2-3 seconds is with respect to the starter/crank time and not the GP on time.
The GP on time is not operator controlled. The computer dictates how long the GP is energized and dependent on coolant temperature. The starting sequence is to put the key in run, wait for the GP dash light to go off and then start.
In colder weather the GP's are activated much longer than the 4 seconds it takes for the GP to turn red hot.
I thought the NGK # might help others with alternatives to purchasing directly from dealer whether it be based on cost, convenience or availability.
/ Glow Plugs... #5
OK, I misunderstood. The smaller Kubota's are a manual selected period of time for the GPs to glow. Yes, once the GPs have warmed things up in there, my BX2200 starts immediately, I would say only 2 or 3 revolutions of the crank if that. Same thing with my larger MF2660 using a Perkins 81 horse diesel. Maybe there is a setting in your system for increasing the GP "on" time before cranking ?
/ Glow Plugs... #6
Did you have remove anything (like the fuel tank) in order to pull the GP's?
/ Glow Plugs...
I only removed one glow plug. The easiest to access. (It was a bit too cold and a storm was pending to risk running into difficulties removing the end ones.)
All four GP's were tested after the buss bar was removed. This could be done without removing anything.
The GP located closest to operator looks questionable if it can be removed due to the fuel tank. The one closest to the radiator also looks questionable due to the AC compressor and supporting bracket for windshield washer fluid.
In other words the middle ones are easy to remove and the ends questionable. I think it's possible for the end ones to be removed and might give it another go when I find time.
The other day it was approximately 15F and it took several GP cycles and a long crank time to start. I'm a bit surprised that after the 10-13 seconds of GP activation there isn't enough to GP heat to start withing 4 seconds of crank time. (Battery is fully charged and I verified state of charge based on specific gravity and ambient temperature. Crank speed seems fast). These glow plugs look white hot in 4-5 seconds.
/ Glow Plugs... #8
Thanks Moship, appreciate all the part no. info. On a 5cyl Mercedes engine I had one dead GP and replacing it made a surprisingly big difference starting at 15 to 25F.
/ Glow Plugs... #9
I had a glowplug problem on a Diesel Toyota, the pre heat timer was not turning off, I disconnected it and used a jumper to the GP's and blew all of them.
Discovered afterwards that they were 6volt despite being a 12v vehicle and the dropping circuit was via two big GP's in the manifold.
I am now aware of what little surprises GP's can have in store for the unwary.
/ Glow Plugs... #10
Thanks for the nice write up. I check amperage rather that voltage, since each glow plug draws about 20 amps cold then a 3 cylinder will draw 60 amps and as the plugs warm they draw less. It's an easy check around that wire you showed with a cheap amp clamp.
The other thing you can check for slow starting is the starter revolutions while cranking, faster is better. My 3940 doesn't seem to have much cranking speed but always starts. Mine cranks around 225 RPM (checked with a labscope on the crank sensor by the fuel pump) and that's not very fast.
Regards, Fred
/ Glow Plugs... #11
Your glow plugs are not igniting your fuel, they are warming up the combustion chamber and head,
I have had good luck in extremely good times cycling the glow plugs 3-4 times giving them 30 seconds or so between cycles.
On diesels with intake manifold heaters I have done similar heat for 45-50 seconds, roll the engine over a turn or two, heat again,
my old Oliver would take about 3 cycles like that then she'd fire up nice, might have to carry the engine with the starter for a few seconds in -10F or colder.
/ Glow Plugs...
UPDATE...
Situation: Temp 12F, battery fully charged.
First attempt was to try 3 glow plug cycles (on-off = 1 cycle) and then engage the starter. The purpose of the multiple cycles was to ensure there was some heat in the combustion chamber. Tractor would turn over at a good rate but not initiate combustion. Did this at least six plus times varying the glow plug cycling scenarios during these attempts (put a charger on battery and waited to make certain voltage didn't drop in battery). Think of this as a mini experiment to see if some magic sequence would work. Motor turns over quickly but it simply would not ignite. Diesel can be smelled from the exhaust.
Made a jumper (12 awg) wire to connect the battery to the glow plug white connector (see pictures). With only 5-7 seconds of supply voltage to GP it started within 1 revolution of the motor. (My wife was inside the tractor while I momentarily touched the wire to the wire connector). In this scenario the tractor GP control and circuit was bypassed. It has never started this quickly since I've owned it with air temperatures 30 F.
So while I have 12 volts to the glow plug buss bar through the tractor/CPU/relay circuit it doesn't have the amps (my guess as I don't have the appropriate DC current probe) to energize the glow plugs appropriately.
In previous tests I know the relay tested good, but guessing it might be faulty or one of the wire connections is not good.
Not certain when I'll be able to test further to find the root cause(s), but the bypass jumper wire helps narrow this down. GP and buss bar to connector OK... So now to test the rest of the circuit.
I'll keep you posted.
/ Glow Plugs...
Did some trouble shooting today and found the root cause!!!
Started from ground zero to double check everything I've done so far.
Cleaned battery positive and ground side terminals, ground to frame, positive terminal to slow burn connectors, removed wire terminals from plastic connector at slow burn fuse, removed terminals from power supply white connector in engine bay, cleaned buss bar and buss bar wire. In other words disconnected every connector cleaned and inspected.
All four Glow Plugs can be removed without removing anything besides the buss bar. Verified GP ohm values and even powered them to make certain they all glow bright red in just a few seconds of power. They stay red hot for at least 8 seconds when energized for 10 seconds. They do become hotter with multiple on cycles.
Verified relays function as they should. Used another battery, lights and jumper wires to make certain they work under light load. Even bought a new 40 amp relay just to make certain. Each relayed was tested using meter and physical test mentioned previously. Stock Relays are 40 amp sealed 4 pin units from Panasonic.
Verified battery voltage at the buss bar when GP activated. What? Why doesn't it want to start? Run a 12 wire from battery to buss bar wire white wire connector and it starts amazingly fast.
So where is the problem?...
There's only one place left to investigate with vengeance. In the relay socket itself. Visually it looks OK and there are no clues it is defective though.
Used a spare male terminal and inserted it into the four connectors on the relay connector. Two were tight and two were very loose. The tight ones were on the control (cpu side circuit, small diameter wire) and the two loose ones were on the power side of relay with the two large diameter wires. This has potential to be the root cause. But now to remove the relay connector from the metal support structure. But how to do so? Used mirrors camera, but nothing clearly visible on how to remove. Elected to slide a 0.010" feeler gauge down between the plastic and metal hoping it would depress the holding tab. Wiggling side to side while pushing downward finally set the housing free. Now to take the housing apart and remove the wires to see what is going on.
The white structure needed to be removed from the black housing by gently prying on locking tabs while trying to remove. It took a bit of effort but it came off. Now to get the wires removed from the housing.
Need to use two small screwdrivers to release the plastic tabs holding the wire terminal in the housing. The terminal/connector is not a common design one would find locally. There is little to no interference when a male connector is inserted to simulate the relay terminal. Tried bending the metal detail that provided the spring force, but after the first insertion it would relax. Ended up using pieces of a paper clip to provide the necessary shim to provide additional clamp force. Not the greatest solution, but it works. Fixed both power side terminals using this method. Reassembled housing, inserted relay with significantly more insertion/extraction force. Now I'm certain there is good electrical continuity between the relay wires and relay itself. If I had more time, more area to work behind the dash and it wasn't so cold out, I'd make up my own relay connector.
The design of these wire terminals is not something that inspires confidence. I'd be hesitant to use them even if I could find a source for them.
Additional comments:
1. The two power side female terminals found inside the relay housing are much wider than the 0.25" wide terminals found on 40 amp relays. They can definitely accommodate the wider terminals typically found on 60 amp relays. I don't think these wider terminals would matter because they are the same thickness and this is the dimension that is critical to generate clamp force to yield good electrical continuity.
2. The relays initially seemed to assemble into the housing with some force, but this was due to the two control side terminals. ie: It masked the poor fit of the power side terminals.
3. I'm guess there was just enough metal to metal contact for the meter to read battery voltage at the buss bar, but not enough to drive the high current demand of the GPs.
4. Purchased a 40 amp relay from Advance Auto for about $9. Currently using have this installed. The housing is slightly larger but it still fits as the pin spacing is identical. Auto Craft 40 Amp HD Relay Part # ACA715A Advance Auto Parts - Down for Maintenance
5. The stock Panasonic relay is nothing special although it is sealed. No diodes, resistors, etc... to suppress voltage spikes when the field is collapsed. (Went through the effort to decode the part number on Panasonic's web site and relay technical info.)
Although the temperature wasn't that low when I finished (28 F). It is amazing how fast it starts after just one GP cycle. It seems to start within one revolution of the motor.
If it's much colder tonight I'll try in the morning and see what happens. At this point in time I'm very confident the root cause has been found.
Hope someone finds this info beneficial.
/ Glow Plugs... #15
Good troubleshooting and a viable repair for a poor connector.
Some wheres I have seen some relays with heavier tabs on the power leads,
I don't recall where or what the amp ratings were would a 60 amp relay physically fit?
They may have the heavier contacts.
/ Glow Plugs...
60 amp relays have 3/8 wide tabs on the power side and 1/4 on the control side. It will definitely fit without issue.
The I致e found mixed information on the 3/8 tab thickness. One source showed them being the same thickness (0.031? as the 1/4 tabs, while another had them slightly thicker. If they are thicker it would help with the compressive force on the tab, but I didn稚 like how the internal detail of the female connector fatigued or lost clamp load on the male connector.
Considering the work involved in taking the connector apart I would recommend buying the larger tab 60 amp relay to see if it works. Especially if the tab is a bit thicker.
I was more into finding the root cause than looking for an easy fix.
Personally I think Kubota blew it on this socket design. It is obviously designed for the large tab 60 amp relay and they decided to use a 40 amp relay with the smaller more popular sized relays. With poor contact the connector is likely to heat up causing fatigue issues reducing clamp load even further. Electrically the 40 amp is adequate but the fit is wrong.
Started the tractor this morning with temps in the 20痴. With one glow plug cycle it started within one revolution of the motor. It starts so quickly now that I just want to keep starting it.
I do have a picture of the smaller tab in the larger connector to demonstrate how much width is available. I値l have to post it later.
/ Glow Plugs... #17
Thanks for the update, good job tracking this down, and nice fix with the paper clip. I wonder if your clearances for the GP are different than on the 5740, i just can't quite see how I would get my glow plugs out without dismantling stuff.
/ Glow Plugs...
Not familiar with this he L5740 layout, but I'm thinking it might have a turbo.
The hardest one is the rear most one under the fuel tank. Having an assortment of wobbly extensions and small flex had ratchet helped. The other three can be accessed with relative ease from the exhaust side leaning in.
/ Glow Plugs...
Yes, the wider tabs on (power side only) will fit. While I didn't have the relay at hand, I did have a 3/8" wide terminal for an old headlight project that fit into the female connector without issue. Sorry, but I didn't take a picture of the 3/8 male terminal inserted as proof, but perhaps the photo below will give confidence in my statement.
The picture also shows the white piece that helps support the wires/connectors in the 2-piece relay socket
/ Glow Plugs... #20
Regards, Fred
What meter do you use with the amp clamp to measure DC? I have never seen a cheap meter with amp clamp that can measure DC, only AC.
I would love to have one.
2013 TIGERCAT 720E FELLER BUNCHER (A64276)
2013 TIGERCAT 720E...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 INTERNATIONAL...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
