Blew a hydraulic hose
/ Blew a hydraulic hose #1
Sigogglin
Goshen, VA
New Holland TC45DA
I blew a hose on my bucket today clearing snow from the drive. I had noticed that the hose was a bit compromised, but didn't expect it to blow on me.
Can someone help me figure out what I need for the hose?
It is for a New Holland 16-LA FEL for my TC45DA.
the New Holland part number is: HYDRAULIC HOSE,9.53mm ID x 438.15mm L, SAE 100R17
Messicks link here: New Holland (16LA) - NH FARM LOADER (12/99-6/6) Parts Diagrams
I can't figure out what the female ends are. They connect to a 3/4-16 JIC x 3/4 - 16 ORB.
I think I need a 3/4" -16 JIC female end? Not sure.
The hose is a 3/4" x 18" SAE 100R17 hose.
I can always go to the dealer and they will make me a hose, but I thought I'd shop around first. It is an hour drive to the dealer.
Just never done much with hoses.
thanks
david
/ Blew a hydraulic hose #2
Skip the dealer and skip trying to figure out t what it is. Remove it and take it to any hydraulic shop, tractor store and some auto parts stores and have them make a new one to match. That is typically how it’s done.
/ Blew a hydraulic hose #3
In my little town in farm country Florida, Chiefland, the local NAPA auto parts store has an experienced full-time employee who makes replacement hydraulic hoses.
The last short Loader hose I had produced at NAPA was $14 and ready in one day. The NAPA replacement has heavier hose than the Kubota originals.
An internet search should help you locate a hydraulic hose shop near Goshen, Virginia. If not, enquire for same at Tractor Supply Company or auto parts shops, someone will know.
/ Blew a hydraulic hose #4
Skipping the dealer isn’t the best advise. Most dealers make up hydraulic hoses while you wait just like hydraulic shops and some auto parts stores. Usually at competitive prices. The female JIC fittings you need are as common as dirt.
/ Blew a hydraulic hose #5
My dealer custom makes hoses, just like 2 of the 4 NAPAs in the area. As others have said, remove the hose & just take it to a local shop for a custom matched replacement.
/ Blew a hydraulic hose #6
thanks
david
A simpler description of the fitting it connects to is;
Hydraulic Adapter JIC x ORB
Male JIC Flare x Male Straight Thread O-Ring, 3/4-16 (-8) x 9/16-18 (-6)
9.53 mm = 0.375" or 3/8" ID hose
so a #8 JIC swivel fittings with an 18" length of 3/8" ID hose, actually shorter as most assembles include the fitting length
as said many places can make one for you, most NAPA stores many farm equipment dealers or snow plow installation shops.
/ Blew a hydraulic hose #7
/ Blew a hydraulic hose #8
Cant add to the hose discussion, but i have been to Goshen VA a few times to the scout camp. Pretty area.
/ Blew a hydraulic hose #9
You might have skipped the end of the OP’s post. He is trying to avoid the 2 hour round trip to his dealer. Any local tractor store or dealer should be able to make the hose. This will possibly save the OP some travel time and add some convenience.
/ Blew a hydraulic hose #10
You might have missed the part where I wrote most dealers make hydraulic hoses. Any dealer, hydraulic shop or old school auto parts store is a possible source. No need to seek out a New Holland dealer.
/ Blew a hydraulic hose #11
When they build your hose be aware that (in my experience) they will most likely use R1 or R2 type of hose unless you tell them otherwise. Your hose is R17 which means it is more flexible and can bend in a tighter radius than the R1 and R2. Other than that for our tractor usage it doesn't make much difference.
/ Blew a hydraulic hose #12
I really dont like R17 hose in the smaller sizes because its usually one wire braid. R16 is what I prefer.
Did the OP get the hose made yet??? Got good advise so far...
Pretty standard hose. 3/8" with 1/2" Female JIC fittings. That hose should cost $10-$15 at a napa or similar.
And another point....Just about all the tractors I have been around, AG equipment always seems to upsize the fitting by one. IE: 3/8" hose with 1/2" fittings. 1/2" hose with 5/8" fittings...etc. My assumption is to not reduce flow through the restriction of the fitting but maintaining the smaller, cheaper, and more flexible hose. But its something that is almost never seen in industrial hydraulics. Almost always hose size = fitting size.
I have not got the hose yet. Had to travel for business.
The closest place for me is the NH dealer. They custom make them, as long as you ask. If you don't ask, they order the OEM part for big dollars.
David
COMBO PORTAPOTTY/TRASH TRAILER (A67714)
COMBO...
Detroit Diesel 3 Cylinder Power Unit (A64912)
Detroit Diesel 3...
2007 TORO 3300-D CART (A66091)
2007 TORO 3300-D...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 INTERNATIONAL...
2007 INTERNATIONAL 4300 SERVICE TRUCK (A66091)
2007 INTERNATIONAL...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
