Loader BX2200 Hydraulics Problem with LA-211 Loader
   / BX2200 Hydraulics Problem with LA-211 Loader #21
The OP's problem sounds exactly like the problems my Dad experienced every year when he went to hook the snowblower up with unmarked hoses (He didn't use the FEL). He always got it wrong and the snowblower wouldn't work, but everything else was ok. (Eventually I moved the controller from the FEL to to the tractor and color coded everything.)
So my vote is there is an error with the hose routing and likely what is stated above.
I know the OP stated he is certain the hoses are routed correctly, but it might be worth having someone else look at the routing to confirm it is to correct.... sometimes we become too close to the problem and it becomes impossible to see the obvious.
   / BX2200 Hydraulics Problem with LA-211 Loader #22
That was one of my first guesses, either a bucket hose and a loader hose cross-connected, or a power beyond line mixed up. I have done the same thing with mixing up hoses on the loader and it doesn't move. Threw me for a loop on our BX2660 when I hooked up the blade as the pairs are the center two QDs and the outer two QDs, not the front pair and the back pair like I was thinking.
Aaron Z
   / BX2200 Hydraulics Problem with LA-211 Loader #23
Sounds like you do not have the BY fitting in the loader valve.
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57453)
New/Unused AGT...
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
78" GRAPPLE RAKE (A52708)
78" GRAPPLE RAKE...
New/Unused AGT Industrial 70-inch Seeder (A57454)
New/Unused AGT...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
BARBED WIRE (A58214)
