Bush Hog BH27 too big for MX5800?
   / Bush Hog BH27 too big for MX5800? #11
The BH is category ll/lll while the Woods is cat l/ll in case that matters. The woods has about 10% better blade tip speed. The BH has a little lower set blades and able to cut down to 1 1/2" height compared to the Woods which as 2" minimum.
   / Bush Hog BH27 too big for MX5800? #12
We used to run a three spindle Liliston 8 foot brush mower behind a 42 HP Tractor. No problem at all.
   / Bush Hog BH27 too big for MX5800? #13
actually think that's called a twin spindle machine with a center divider box.
   / Bush Hog BH27 too big for MX5800? #14
It had three sets of blades, two pivoting on each spindle to help when hitting things. Which we did a lot! My Dad spent a lot of time under there! lol At one point we tried sharpened, cut up truck springs.
The other thing I can get with the Woods is dual wheels which I like to help reduce scalping. Was quoted $3900 and 90 day wait for a new one with the dual wheels and chains. Think I could buy the BH27 for $2750 but am convinced it's just too big and would be better to go to a pull type 8' dual spindle if I want to go bigger.
   / Bush Hog BH27 too big for MX5800? #16
Not sure I have seen a brush mower with anti scalping rollers. Usually, you're not that close to the ground to need them.
   / Bush Hog BH27 too big for MX5800? #17
i stand corrected.... interesting set up, would like to see ... best regards
They aren't technical anti-scalp rollers, just two support wheels on the back (more like an 8' cutter) instead of one. It doesn't allow the cutter to bottom out as much on a single side when going over undulations. Another benefit is it is shorter than a cutter with only one support wheel.
   / Bush Hog BH27 too big for MX5800? #19
We bought it surplus from the Canadian Armed Forces in the 60s. We had no hydraulics on our first Massey Harris tractor, so you had the crank the two trailing wheels up and down. Our next tractor had a 3ph so we put a drawbar on the lifting arms and adjusted it that way. Today, I would have replaced the crank with a cylinder.
I'm sure Liliston is LONG gone, but it was a great design.
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
2002 Frieghtliner Pressure Digger (A55973)
2002 Frieghtliner...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
LOT: (2) Truck Brake Part #'s 66864B, (2) Truck Brake Part #'s RK8354709E2 (A59076)
LOT: (2) Truck...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
LOT: (2) Shelves of Komatsu Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (2) Shelves...
