My new transfer tank set up
   / My new transfer tank set up #21
Ha, ha - - Doofy. I remember going to the little cabin at the DOT in "down town" Glennallen and filling our jugs with fresh water. Putting them in our little rental cabin so they wouldn't freeze solid. What a life.
One of these days, when I get a round tuit I'm going to have to do something about fueling the tractor. Full 5 gallon Jerry cans are becoming a little much.
   / My new transfer tank set up #22
Halftrack - VERY nice and clean looking unit. Definitely a tad outside the $8 category.
   / My new transfer tank set up #23
I could maybe use a gravity to fuel the zero turn but the tank on the tractor is way to high I would have to put it up on the loaded to make it work.
Yup, use the loader
You could probably do this with 5 gallon Jerry cans
586114d1546777321-my-new-transfer-tank-set-8oo-20180707_182913-jpg
Let gravity be your friend.
Gravity is a law.
   / My new transfer tank set up #24
oosik, DOT closed down that well around 1990 because it was costing to much to maintain. The water stunk and was loaded with methane. I burned off my eyebrows several times when thawing the barrel bung with a propane torch. Priceless times.
   / My new transfer tank set up #25
Looking at some of these options, don't you run into an issue with dispensing fuel into a non-DOT approved container?
   / My new transfer tank set up #26
Yup, use the loader
Gravity is a law.
Brilliant!!!! I'm not yet to the point of 5 gal. cans being too much to handle but the day will come and I am going to use this method........if I can remember it!! :confused:
   / My new transfer tank set up #27
Yup, use the loader
Gravity is a law.
Newbury, is this your setup? Is there a way to shut the gravity flow off at the tank if you need to while the container is up in the bucket? Can't tell from the pic if that's a shutoff nozzle on the hose. I ask because I'm perfectly capable of overflowing my tanks even when I only have the 5-gal fuel can in my hands! :)
   / My new transfer tank set up #28
]After decades of using a drum, and finally puncturing it one day, I decided to grow up and invest in a different set up. Sure glad I did. I do have forks, and it sure beats wrestling the drum in and out of a pickup and front end loader.
Well I scored a new tank ! no more barrels. 50 gal Day tank free !
I just need to clean it out and weld in a bung for the pick up tube and enjoy !
   / My new transfer tank set up #30
Excellent score! Those tanks are skookem.
KMC 70Z7 WHEEL LOADER (A52709)
KMC 70Z7 WHEEL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Crane Truck (A55973)
2015 Kenworth T880...
2021 Caterpillar 300.9D Mini Excavator (A55973)
2021 Caterpillar...
1992 BYQ Boat and Trailer (A56859)
1992 BYQ Boat and...
2016 Jeep Compass 4X4 Sport (A56859)
2016 Jeep Compass...
