Is air ride my solution?
/ Is air ride my solution? #1
cold1313
Gold Member
Northern, Ohio
Kubota M4D-071 Kubota F3990
I have an F3990 to cut the grass which takes me around 3 hours of run time. My yard is quite bumpy, some slopes, etc so I'm always in low gear and can never "floor" it in low gear. I get bucked around too hard.
My issue is my giant sized head and the sore neck I get after mowing. I'm guessing I look like a bobble head doll when I mow.
Would an air ride seat fix this issue? I have the factory Kubota suspension seat adjusted to my weight and I've played with it heavier and lighted. I can bottom out the seat every once and awhile. I'm not the lightest person at ~250'ish pounds.
What also started this is that mice have gotten into the back of the seat already this winter and have started remove the foam. I'm furious.
Would an air ride stop my head from bouncing all over the place, or make it worse? I was trying to find just a basic air ride seat but the Grammar ones start adding in heat seat options, etc...I don't need any of that.
Suggestions?
/ Is air ride my solution? #2
I would like to know what some informed users say about this. Been wondering the same thing. My mower is a F2690...I don't know if there is a difference in the seats already.
/ Is air ride my solution? #3
I was looking into converting to an air ride seat on my F2690 also. My 'lawn' (basically pasture) is also really rough, some slopes, and takes about 2-3 hours. I ended up just letting almost all of the air out of the tires (I think I'm at about 6-8psi right now) and the ride improved dramatically. It ended up being OK-ish enough that I decided I didn't need the air seat afterall. The tires look like they are flat but as long as they have enough air to keep the rim from bottoming out it seems to work pretty good. Ran like that all last year without any problems.
Sounds like we are in a similar situation. I aired them back up for this past year but I probably mowed less than half of normal - we had so much rain that I wasn't going to rut the yard to cut the grass.
My concern with the air ride is will I "bounce" or sway too much and actually have more neck issues? (Due to my oversized head) I'm a younger buck at 34 years old but I don't see myself getting better with age! Plus I could pull this seat and put it on the next machine...hopefully very far down the road.
/ Is air ride my solution? #7
Think its just the nature of the best. If you soften the seat, the deck still bounces and then the grass doesn't get cut very well. I cut about 5 hours each time and just know where the rough spots are. Don't know what your lawn looks like, but I'm figuring the best way would be to use a lawn roller after its been raining a couple days
/ Is air ride my solution? #8
Yes air ride will help. The mice wont do the air ride seat any favours.
I'd have to spend probably a day on a lawn roller and with the slopes, it might end up dragging me down a hill with my luck! I don't think it would help. With the freeze and thaw, things are always moving a bit.
/ Is air ride my solution? #10
I have the same problem with my lawn. The roughness wears on a guy as you get older. I've often wondered if a Harley rake set to chew away at the high spots would make enough of a difference to make the lawn smoother.
I know the approach is different than an air seat but I want to get to the same point. A smoother ride.
/ Is air ride my solution? #11
I installed couple of these in my jet boat few years ago and am tempted to "borrow" one of them in order to try out in a mower!
(They cost $330 each at a local boating seat supply specialty shop at the time)
It's a mechanical suspension with heavy duty springs and shock absorber. The height is close to 8 inches which would not be an issue, once the Kubota seat suspension was removed.
These are working very well in my jet boat.
Snap 2019-03-27 at 15.00.11.jpg Snap 2019-03-27 at 09.49.27.jpg Snap 2019-03-27 at 09.49.45.jpg Snap 2019-03-27 at 09.50.04.jpg
Question:
Have any of you tried this type of seat suspension in a mower?
/ Is air ride my solution? #12
it may sound ludicrous but consider getting a heavy duty wide strap on back support. strap it on tight. this will upright your posture and allow the back to properly accommodate the shock. drive slower. after all, the back itself is a type of shock absorber
have extensive feral hog damage. as mentioned, reducing air pressure helps. @ 71, fortunately i'm light enough for this not to be a problem. just hope the machinery can handle. i do understand, though, it does take it's toll on a lot of people.
best regards in finding that comfort zone.
2022 EZ-GO ELITE...
Sunflower Yard Art (A64557)
Sunflower Yard Art...
2015 Ram 5500 RKI 10ft. Utility Flatbed Truck (A64194)
2015 Ram 5500 RKI...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2020 CATERPILLAR 299D3 SKID STEER (A65053)
2020 CATERPILLAR...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
