Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #7,101
My next challenge is getting the trunk of this birch in the background outta here. To the right of the tree in the front center of the water is a 4' deep watering hole. I don't know if there is a spring under here, or it's just a low spot that collects water. The water hole hasn't been dry in years, only briefly during our last drought. The animals use it to drink so I don't want to take a chance in contaminating it or driving near it. I do like a challenge. IMG_20181225_132800_1.jpg
   / Tractors and wood! Show your pics #7,102
Is there room to come around from the uphill side and just grab it and pull it up and over the hill? Then you can drag it out, or cut it up and haul it.
   / Tractors and wood! Show your pics #7,103
Got 6 of these dumping hoppers that were going to be scrapped where I work.
Part of them have holes in the bottom for water to drain out. I'm thinking about putting a drain in the others.
   / Tractors and wood! Show your pics #7,104
My next challenge is getting the trunk of this birch in the background outta here. To the right of the tree in the front center of the water is a 4' deep watering hole. I don't know if there is a spring under here, or it's just a low spot that collects water. The water hole hasn't been dry in years, only briefly during our last drought. The animals use it to drink so I don't want to take a chance in contaminating it or driving near it. I do like a challenge.View attachment 585543
When it freezes over go get then. It looks like that hole needs a cleaning out as well.
   / Tractors and wood! Show your pics #7,105
Why take it out at all? Let it rot for the critters.
   / Tractors and wood! Show your pics #7,106
A full hopper lasts about 12 days.View attachment 585547
That would be awesome to have those around.
Rust
   / Tractors and wood! Show your pics #7,107
I was leaning towards that idea, It's a waiting game, I need it to be cold enough to freeze the water solid, but not a ton of snow or it will have to sit until it melts, there is really no good way to get in there with a lot of snow on the ground.
   / Tractors and wood! Show your pics #7,108
That's about 2 weeks of good firewood, too much to leave for the critters, they will just have to live in the wall next to it.
   / Tractors and wood! Show your pics #7,109
If you're going to leave it till later, I would block it up off the ground so it doesn't rot first.
Let some of mine go too long & lost a bunch of good firewood.
   / Tractors and wood! Show your pics #7,110
Got 6 of these dumping hoppers that were going to be scrapped where I work.View attachment 585547
My brother has some of those. He put an axle under one and used it for hauling sand and firewood for many years. He could pull it with his tractor and dump the sand where he wanted it.
SR
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2016 E35 Bobcat Mini Excavator (A50322)
2016 E35 Bobcat...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2007 WABASH 53FT DRY VAN TRAILER (A51222)
2007 WABASH 53FT...
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK WITH A SNOW PLOW (A51222)
2012 FREIGHTLINER...
2018 FREIGHLTINER CASCADIA TANDEMA AXLE SLEEPER (A52141)
2018 FREIGHLTINER...
